Gateway Performance 866 (ATX-STF)_Socket370_Need the usual
Contact:
Post by evasive »
The offer itself is nice, it's too bad those boards seem less than standard quality...
joe_devore
Contact:
Post by joe_devore »
Edited and moved to TECH-Support sub-forum.
joe_devore
Contact:
Re: Gateway ATXSTF Performance 866_Socket370_Need the usual
wow I ran into this old thread of mine... its been ten years...
I still have this old PC sitting around in the closest.. I found I could more or less get ReactOS to run.. now I'm just trying to get either
XP or Win2k drivers for it...
(PC Specs)
CPU: AMD FX-9590 4.7GHz 8-core
CPU Instructions: MMX(+), SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, SSE4A, x86-64, AMD-V, AES, AVX, XOP, FMA3, FMA4
Motherboard: Asus SABERTOOTH 990FX R2.0
GPU: nVidia GTX 1070 Ti 8GB
GFX Drivers: Nvidia v431.60
OS: Windows 7 Ultimate 64-bit SP1
RAM: 32GB Kingston 1866MHz DDR3
Post by Karlsweldt »
Can you get a BIOS string and post here? Would help sort out the proper model/version.
joe_devore
Contact:
Hey Karl,
ok...
on a side note ReactOS is not fully detecting the CDRW drive... so it is not showing up in Device Manager... and my USB flash drive is not being detected either...
so I have no way of getting the drivers on to my old PC at this time :(
besides that, the ReactOS USB driver support is still young, so if I have my simple Microsoft USB Optical Mouse plugged in, the boot of ReactOS hangs on that driver.. but if I plug it in after it reaches the desktop its fine... lol :roll:
BIOS String:
Code: Select all
EA81510A.15A.0012.P09
(PC Specs)
That "EA81510A.15A.0012.P09" looks more like the model tag string.
Have a Gateway socket 370 mobo, out of a "MFATXSTLKTH 300S". Did have Win XP on it, maybe the drivers are on the OS disk?
joe_devore
Contact:
Karlsweldt wrote:That "EA81510A.15A.0012.P09" looks more like the model tag string.
this is an old Gateway PC , that before it was given to me originally had Windows ME ( :p ICK)
after it was given to me I put a new HDD and windows 2000 Pro on it.. it served me from 2006 till I got a new PC was given to me in 2011..
it is the BIOS string... its the equivalent of a Intel D815EEA mobo... P09 is the bios version # and there is no further updates for it since the only bios updates available are for the intel oem and not the Gateway oem mobo
https://downloadcenter.intel.com/produc ... rd-D815EEA
and I just built my first new AMD 8 core PC June 2016 the specs for my new PC can be seen here at CPUz Report http://valid.x86.fr/ssns8i
This old PC has an Intel Pentium 3 866MHz CPU and, I upgraded it with a new 80GB HDD IDE, a ATI/Sapphire Radeon 9800 SE 128MB gfx card AGP 4x/8x, and 512MB of SDRAM (2x 256MB sticks)...
I just found my old stored copy of my Win2k Drivers... though I don't know if ReactOS will take them though since ReactOS is modeled after Windows Server 2003 and WinXP
so far my one of USB flash drives and a basic burned CDR are not being seen by ReactOS so I can't even get the drivers on to it... :( >_<
(PC Specs)
Contact:
Post by evasive »
XP drivers for that LAN chip:
https://downloadcenter.intel.com/downlo ... al-Release
XP drivers for that Sound chip:
https://downloadcenter.intel.com/downlo ... AC-97-ADI-
XP drivers for that Graphics:
https://downloadcenter.intel.com/produc ... -Hub-GMCH-
The chipset should have native support from the OS. I remember running XP on one of these (albeit an Intel retail board).
joe_devore
Contact:
Hey Evasive, Thanks for the research and download links...
:D
(PC Specs)
Post Reply
