Gateway Performance 866 (ATX-STF)_Socket370_Need the usual
joe_devore
Contact:
Post by joe_devore »
Hay guys I back again....
Got a system Mobo needing ID'ing..
Its a
"Model No. Gateway ATXSTF Performance 866"
MFG Date:: 10/15/2000
Serial# 0020826535
Its has a Socket 370 Currently running a Pentium3-866MHz([email protected]).
THE Important stuff
I haven't started it up yet (still cleaning it out, It was Nasty Dirty)
so I don't have the BIOS String yet, POST it as soon as I get it..
For the really good INFO 8)
NORTH BRIDGE::
Intel 815
FW82815
L031HL03
SL4DF
INTEL (M)(C)'99
SOUTH BRIDGE::
Intel
FW82801BA
L0300045
SL45H
INTEL (M)(C)'99
MY copy of Scott Mueller's Upgrading&Repaing PCs 11th edition is just one
Edition short of the Info on these chip sets
PDT_Armataz_01_02
I would like to know what there full capibilities are, thanks..
Its an ATX Board (Nice... something newer to work on for once :) )..
3 SDRAM slots, Running 1 - 64MB SDRAM PC133 (CL3)
5 PCI slots
1 AGP
1 CNR
3 USB ports (2 Back, 1 Internal Header for front)
1 Intergrated Graphics Port (Direct AGP?)
1 Serial & 1 Parrallel
No Intergrated Audio
Standard Keyboard&Mouse PS/2 Ports
Here are some Info for the Board and 2 stickers
On-Board:
E139761
N232
Sticker#1
4000684
Sticker#2
IMEA003606635 AA A19243-207
BIOS Chip::
Intel N82802AB8
A02250368
(M)(C)'96'98
DirectAGP 4MB RAM CAHCE+Graphics Support
KOREA
Glue 3
A05770-002
MB87B301B
0028 X40
Super I/O Chip::
SMsC^(M)
LPC47M102S-MC
B0030-A9462
8G24030-7
AMERICAN MEGATRENDS (C) 1994
Thats All I really have on the Mobo..
I get the BIOS String as soon as I can get it booted. :)
Thanks for all your help as always.
joe_devore
Contact:
Entras
Goggled for some interesting Info
http://www.kamcom.com/gateway/gateway4.htm
4000700 Gateway PGA370 E139761 DIMM Motherboard
doesn't match the Sticker:{4000684}
Found this
GatewayMyDownloads: Model: PERFORMANCE 866
hmm...
Enter this when asked..
Serial Number: 0020826535
profofpcs
Contact:
Post by profofpcs »
Intel Fedora board most likely, pictures here and support docs here
[url=http://www.motherboards.org/folding/index.html][img]http://server3.uploadit.org/files/cacrusn-waynestagbyJana.jpg[/img][/url]
Contact:
Post by evasive »
Gateway OEM version of the Intel D815EEA (Easton)
You can use everything from Intel (drivers/docs/specs) apart from the bios.
joe_devore
Contact:
Hay Evasive how life going for ya.. :)
Thanks as always...
Did you see any if the mini-??? I had scattered throughout my post?
The WebLink profofpcs provided to a Pics&Info of the Info seems right..
It looks Identical to the board I have, except the Model/Sticker #s don't match???
Anyway the info doesn't Tell What Version USB it supports
Super I/O:
Universal Serial Bus
* UHCI Implementation with four ports
* Supports Wake from sleep states S1,S3 & S4.
* Supports legacy Keyboard/Mouse software
Never mind other Info says USB rev1.1
joe_devore
Contact:
Hmm.... there are a few strange things about this mobo...
There is a Weird Connector coming from the power supply connected to
Fan(3-Pin)#4,
btw there are 3 of 4 3-pin FanPowerHeaders
1, 3, 4..
#2 which is closest to the NorthBridge, and lies in Grid(F, 3)..
It was labled P(the 3-pin [email protected])
2 wires.. Black+ Purple
Pin#1= Black= Ground?
Pin#2= Purple= ???
Pin#3= Empty= Empty
Maybe a mistake? when they wired it......
Very Unusual....
Any Guess?
Contact:
Post by evasive »
It is one of the first i815 boards out there, I'll have an educated guess on what's going on.
joe_devore
Contact:
????????? -- Thats a bit confusing....
Clicked for Further Info on that 3-pin connector...
Say:
APM Fan Connector:
A keyed, 3-pin connector from the power supply connects here and allows the computer software to control the fan, turning it on or off, thus overriding the power connector. If SCSI devices are detected in the computer, the fan remains on.
F - APM Fan Connector
Solves that problem.. Sucks those I wanted more FanPowerConnectors,
Not near enough too cool this Board,
Heatsink/Fan Cooler
1 for Northbridge
1 for Southbridge
1 for CPU
Now for the upgrades need....
It does look like too bad a mobo,
much better than what I am running at this very sec..
Current is a 437VX, and a PIIX3
AMD K6-2, 300MHz, Socket7, Suk
Whada think, needs some serious upgrades though..
Current Config.
Pentium 3 866MHz, socket 370
128MB SDRAM PC133
200Watt ATX PS (this has gotaGO)
DirectAGP Graphics....
Heatsink NO FAN
(Can't believe it runs at all, my 300MHZ is running HOT w/ a FAN)
So whada ya think
(lol, yeah right its obvious, This PC was destined for the scrap heap)
Thanks again.
Contact:
Post by evasive »
you can fit up to 1024MB of PC-133 SDRAM or 1536MB of PC-100 SDRAM
http://www.intel.com/support/motherboar ... 013066.htm
fastest supported CPU is 1.0GHz P3
http://www.intel.com/support/motherboar ... 013068.htm
That 300MHz was made with older less efficient transistors so generates lots more heat than the new one. If you're not overclocking you don't have to cool extra. You can't overclock this board so that's simple, leave as is.
If you're not going to fit some MONSTER graphics card you don't need to replace the power supply.
You could fit a newer faster harddisk (7200RPM) and at least 512MB of memory. Those two things will greatly improve speed.
joe_devore
Contact:
So are you saying that a 512MB PC133 SDRAM, 866MHz P3
I was figuring at most ATI Radeon 9550 128MB AGP + above
I have a 64MB ATI Radeon 7500 PCI
2 Port USB 2.0 PCI
10/100 Kingston PCI NIC
AudioCard... hopefully
my Samsung SW-252B and a
DVD ROM Drive.. hopefully
could all be run a 200 Watt PS ATX?.... :?
to Run really stable it should have at least 350 WATTs shouldn't it??
.....oh miss read that monster GraphicsCard statement
so it will need a 350Watt or more?
I got another problem with the other PC I am working on....
I post it in the tech support, look for it mobo is a
EliteGroup(P4VXAD_rev1.0)
Oh yeah the Current HDD that came with it is a
Quantum Fireball PLUS LM, 3.5 Series
GTLA: LM20A011-01-A 20.5AT
Is it any good or should I be very Wiery of relying on it??
Size? 20.5GB?
Post Reply
