ollE Anti-Static Strap
Tulatin Enlightened Master
Posted: Tue Jun 27, 2006 2:09 pm Post subject: |
Wow, talk about an indepth article. Watch your fingers around the caps, though  |
nelis Pilgrim
Posted: Wed Jun 28, 2006 3:35 am Post subject: |
| Cool article... |
razialx Pilgrim
Posted: Wed Jun 28, 2006 4:26 am Post subject: |
Can anyone answer a power supply question for me:
I was running some monitor software the other day, mostly to get a temperature reading of my computer, and the software also displayed my voltages for my power.
All were in the proper ranges except the -5V. It was hovering around a -3.99V, which was causing it to flash red (annoying hehe).
The power supply is new, along with most of the components. Is this something I should be very concerned about...
Thanks
Tim
AMD Althon X2
PS: 500W
Geforge 6800
2 Hard Drives
DVDRW
NForce 4 MBO |
jonnyGURU Green Belt
Posted: Wed Jun 28, 2006 5:56 am Post subject: |
| razialx wrote: |
That's because your motherboard doesn't use -5V. In most cases, the ATX power supply doesn't even HAVE a -5V rail or lead. So, as typical with most software voltage readings, your reading is bogus.
And for the record, the title of the article should be "ATX Power Supplies 101." Yeah.. that should SEEM obvious because this is MOTHERBOARDS.ORG... a PC hardware site, but the article got digged and that was the first point to come up. Freakin' nerds. Have nothing better to do then to split ends on verbiage.  |
razialx Pilgrim
Posted: Wed Jun 28, 2006 6:20 am Post subject: |
What was that second part about? Did I do/say something wrong?
If so, sorry. |
Posted: Wed Jun 28, 2006 7:01 am Post subject: |
| razialx wrote: | What was that second part about? Did I do/say something wrong?
If so, sorry. |
No. I wasn't addressing you. Just making a general statement about the article. |
rawsteak Pilgrim
Posted: Wed Jun 28, 2006 8:27 am Post subject: power supply hack |
i don't know if this is really a hack, but I was curious about something. My current set up does fine with the power supply that I have now, but if I want to upgrade my system with a 6600GT video card, I need a stronger and better PSU because the card needs its own molex connector, and my computer dies if I try to use the PSU i have now.
would I be able to, in theory, use another lesser PSU outside of the computer, connect the Power On lead to "energize" the PSU and connect a molex connector from the external PSU to the video card in my computer whose other peripherals are connected to the original PSU? what are some possible scenarios? a good power supply will run me about $70-$80 (or more since my friend is pushing me towards antec) which isn't a lot, but I'm kind of in the red right now and I'm tired of using the on-board video card which is crappy.
thanks! |
Trisped Pilgrim
Posted: Thu Jun 29, 2006 11:44 am Post subject: |
Good guide, it explained a lot about PSUs and what to look for. I like how you showed how to trick the supply on. I also like the look at PFC and the info on efficiency and derating curve. I am looking forward to the 201 class where you talk about independent voltage regulation and crossloading.
Typo
http://www.motherboards.org/articles/guides/1487_7.html
If a power supply draws less AC to produce more DC, then that power supply is more efficient then one that draws more AC to produce the same amount of AC.
Last AC should be DC. One letter, big difference.  |
