ollE Anti-Static Strap
Oylpann Black Belt 3rd Degree
Joined: 10 Nov 2004 Posts: 3843 Location: Oklahoma City, OK
Posted: Fri Feb 10, 2006 11:17 am Post subject: |
I've seen some reviews of the 7800 GS on some other sites. I'm not that impressed. Not to say that I wouldnt take one over my 6600GT though.  _________________ "You cant hug your family with Nuclear Arms"
ABIT NF7-S2
Sempron 2200+ @ 1.8GHz
1GB DDR400 Vanilla Crucial
XFX 6800XT
250GB Maxtor DiamondMax 10
CoolerMaster Case
OCZ ModStream 450w |
Chadster Brown Belt
Joined: 10 Apr 2004 Posts: 279 Location: Cayman Islands
Posted: Thu Apr 13, 2006 12:58 am Post subject: |
Hello,
Am I correct in thinking that;
1, This is pretty much the best AGP card out there now?
2, With my spec (AMD64 3000, 1.5Gig Ram, 5900XT graphics card) this should make a huge difference and I might be able to play TES: Oblivion on a higher setting than the lowest?
Thanks for you time _________________ Help humanity .....join the
Motherboards.org
folding team! 33258
Tolemac Mobo-fu Master
Joined: 12 Sep 2000 Posts: 14272 Location: L-1 Bridge
Posted: Thu Apr 13, 2006 1:54 am Post subject: |
Well I'd say that the BFG 7800GSOC is a better card, even if the XFX has a higher clock and memory speed (only just, though. 440MHz vs. 400MHz GPU and 1.3GHz vs. 1.25GHz memory) The BFG can be overclocked very nicely and IMHO is a much more rugged card.
Indeed, with your current setup, you'll able to pop in either one of these cards and see a huge performance difference from what you have now. Obvilion will be looking amazing at full settings.  _________________
The Gift of Healing |
Chadster Brown Belt
Posted: Thu Apr 13, 2006 2:09 am Post subject: |
Cool, I will eventually upgrade to PCI Express and decent CPU, but if this will do in the mean time and I can get Oblivion to anywhere near full settings I will be more than happy, oh and I will be able to play FEAR with decent settings now aswell hopefully..... _________________ Help humanity .....join the
Motherboards.org
folding team! 33258
