Heres one for ya MoboCop
Postby Toby B. » Fri Jul 15, 2005 10:44 am
1064: You have an error in your SQL syntax. Check the manual that corresponds to your MySQL server version for the right syntax to use near 'ORDER BY mm1.date DESC' at line 7
Warning: mysql_fetch_array(): supplied argument is not a valid MySQL result resource in /home/virtual/site1/fst/var/www/html/includes/int_libs/classes/db_mysql.php on line 52
No manuals found for Mitac 6110ZU
http://www.motherboards.org/mobot/manua ... 6110ZU/va/
Toby B.
Postby evasive » Sat Oct 22, 2005 10:39 am
it trips over the forward slash in the board name I think 6110ZU/VA
Postby Toby B. » Sat Oct 22, 2005 6:40 pm
evasive wrote:it trips over the forward slash in the board name I think 6110ZU/VA
Yeah that must be the issue, but needs fixin.... :? :oops: :oops: :?
Toby B.
Return to Motherboards.org Web Site
