BIGMAN131307 Black Belt 2nd Degree
Joined: 07 Aug 2001 Posts: 2152 Location: " Say 'ello to my little friend! "
Posted: Sun Nov 21, 2004 1:42 am Post subject: |
Im not an expert at web coding, but it seems that the login issues started during the sites facelift... Could that be the culprit, causing these problems? Since it only Firefox, Mozilla, Netscape and not IE being effected?? _________________ GO GREEN |
evasive Mobo-fu Master
Joined: 06 May 2001 Posts: 36377 Location: Netherlands, Breda
Posted: Sun Nov 21, 2004 2:02 am Post subject: |
firefox problem was already there long before the facelift. troubles started after the forum software upgrade to version 10, problem has been solved with version 11 if you kick out the old cookie, I think the cookies format has changed... _________________ We hate rut, but we fear change.
MoboCop Drunken Master
Posted: Sun Nov 21, 2004 3:06 am Post subject: |
the problem actually happened when we switched to a new server. _________________ Not everything that can be counted counts, and not everything that counts can be counted - Albert Einstien |
Wyrm73 Black Belt 1st Degree
Posted: Mon Nov 22, 2004 10:33 pm Post subject: |
It seems that many of the other issues are fixed now, but still no topic notification (at least for me). Is it working for everyone else?
I have tried clearing both IE and Firefox. I also tried posting with each. I tried turning email notification off and then back on. I even double checked my screened mail to make sure they weren't getting filtered. |
Toby B. Lead Mobo-fu Master
Posted: Mon Nov 22, 2004 10:41 pm Post subject: |
| Wyrm73 wrote: | It seems that many of the other issues are fixed now, but still no topic notification (at least for me). Is it working for everyone else?
I have tried clearing both IE and Firefox. I also tried posting with each. I tried turning email notification off and then back on. I even double checked my screened mail to make sure they weren't getting filtered. | When your posting, check to see that the "notify me when a reply is made" box is checked. Otherwise you will not get a notification. _________________ We Help You. You Can Help Us!
Link to us from your pages |
S33K3R Black Belt 2nd Degree
Posted: Tue Nov 23, 2004 8:44 am Post subject: |
@MoboCop
how did you come to the conclusion that it was a cookie
I think as I mentioned before I saw similar troubles at other site and it too was cookie issues
seems to be working fine
good job |
Posted: Tue Nov 23, 2004 5:32 pm Post subject: |
| S33K3R wrote: | @MoboCop
good job |
Desperation. I had tried changing the cookies before when the problem first cropped up and it did not help.
So this latest go around I spent a few hours searching and searching for a solution. I came across this script on phpbb forums that detects the correct cookie setting for you and updates the config. Having gotten no where I said what the hell and ran it.
It worked. _________________ Not everything that can be counted counts, and not everything that counts can be counted - Albert Einstien |
Hardware Junkie Mobo-fu Master
Joined: 25 Jan 2001 Posts: 19349 Location: 00000h - 0000Fh
Posted: Tue Nov 23, 2004 5:42 pm Post subject: |
| Quote: | | Having gotten no where I said what the hell and ran it |
What the hell...I just push the red button and lets see what happens....  _________________ "Imagination is the only weapon in the war against reality." -Jules de Gautier
Posted: Tue Nov 23, 2004 5:51 pm Post subject: |
| Hardware Junkie wrote: | | Quote: | | Having gotten no where I said what the hell and ran it |
What the hell...I just push the red button and lets see what happens....  |
well not quite exactly what happened. I did back up the config file first. _________________ Not everything that can be counted counts, and not everything that counts can be counted - Albert Einstien |
Posted: Tue Nov 23, 2004 9:59 pm Post subject: |
| Toby B. wrote: | | When your posting, check to see that the "notify me when a reply is made" box is checked. Otherwise you will not get a notification. |
I have it set in my profile as the default to always notify me. It always seems to be checked when I post (it is for sure on this post). |
