Need help Overclocking my Soyo P4S Dragon Ultra!
Postby Ben77 » Fri May 24, 2002 10:13 am
My question is the same as Worleybird who posted earlier, but my specs are a little different. Also, I'm using the cpu fan that came with my cpu, any suggestions? Please Help!
P4 1.8 ghz
Antek servercase 330watts- 4 case fans
MSI Geforce4 ti 4400
Raid 0 : two 80 gig 7200rpm hard drives
Samsung 512mb DDR 7200rpm ram
Where should I start with on the following:
CPU:DRAM ratio
CPU clock (FSB)
CPU Clock ratio (Auto or 8x to 50x)
Autodetect DIMM/PCI Clock (disabled or enabled)
Spread Spectrum (disabled or enabled)
CPU Vcore
DDR Vcore
AGP Voltage select
What should I do with the advanced Turn up settings?
CAS latency
RAS active time
RAS precharge time
RAS to CAS delay
ACT to ACT delay
Write Recovery time
R/W turn around time
Read Latency control
Time constraint control
GW Write Mask AGP Request
AGP Fast Write Capability
Refresh Cycle time
DRAM Addr/cmd rate
What about?
CPU L2 Cache ECC checking
Prefetch Caching
AGP Aperture size
Ben77
Postby Aibohphobia » Fri May 24, 2002 12:32 pm
You can find much on RAM info here: http://www.pcguide.com/ref/ram/timing.htm
And http://www.itcp.net/~awsh/Speed_Demonz/ ... _Index.htm for almost everything else.
Goddam mad dog!
Aibohphobia
