n30nx Anti-Static Strap
Joined: 02 Aug 2003 Posts: 442 Location: Cambridge, Ontario, Canada
Posted: Mon Aug 16, 2004 1:14 pm Post subject: is this possible? |
Ok, try to help me understand this diagram to see if this is possible, I need to know..
DSL Modem To wireless router
wireless router transmits to pc1 via wireless b pci adapter
pc1 uses ethernet port and a lan cable to connect to pc2
pc2 can use the lan cable from pc1 to use pc1's wireless connection
shared of course.
is it possible? I dont have the money for pc2 to have a wireless adapter, and it cannot go close to the router, space restriction. and a long cord is not an option _________________ Cele 1.8ghz
1gb SD100
ati radeon 9200se
sb live 5
Hardware Junkie Mobo-fu Master
Joined: 25 Jan 2001 Posts: 19351 Location: 00000h - 0000Fh
Posted: Mon Aug 16, 2004 4:14 pm Post subject: |
Yes this is possible. You just need to set up PC1 as a router or share the network connection. _________________ "Imagination is the only weapon in the war against reality." -Jules de Gautier
Posted: Mon Aug 16, 2004 5:44 pm Post subject: |
and how is this done? I'm new to that networking component.. _________________ Cele 1.8ghz
1gb SD100
ati radeon 9200se
sb live 5
Posted: Mon Aug 16, 2004 6:20 pm Post subject: |
Which Operating System(s) are we talking about? _________________ "Imagination is the only weapon in the war against reality." -Jules de Gautier
Posted: Mon Aug 16, 2004 7:00 pm Post subject: |
both xp pro _________________ Cele 1.8ghz
1gb SD100
ati radeon 9200se
sb live 5
Posted: Mon Aug 16, 2004 7:15 pm Post subject: |
Network Setup Wizard on both machines should suffice. Just follow the instructions on screen. _________________ "Imagination is the only weapon in the war against reality." -Jules de Gautier
Posted: Mon Aug 16, 2004 7:44 pm Post subject: |
doesnt the network setup wizard need to be used from the xp cd? _________________ Cele 1.8ghz
1gb SD100
ati radeon 9200se
sb live 5
dr_st Black Belt 2nd Degree
Posted: Mon Aug 16, 2004 8:26 pm Post subject: |
| n30nx wrote: | | doesnt the network setup wizard need to be used from the xp cd? |
No, not on XP. |
Posted: Tue Aug 17, 2004 7:06 am Post subject: |
but it can be run straight from the control panel one then? _________________ Cele 1.8ghz
1gb SD100
ati radeon 9200se
sb live 5
Posted: Tue Aug 17, 2004 5:45 pm Post subject: |
You just go to Start --> Network Connections --> Network Setup Wizard.
or Start --> Control Panel --> Network Connections --> Network Setup Wizard. _________________ "Imagination is the only weapon in the war against reality." -Jules de Gautier
