bobg831 Pilgrim
Posted: Sun Aug 15, 2004 8:26 am Post subject: CMOS Battery |
I have an old biostar MB-8500tuc-a (ver3.2) Motherboard.
it is in a pionex box. my friend gave it to me to look at for her.
after adding ram,(it only HAD 32mg on it), i find it has CMOS problems
NO battery. i dont see a battery spot on the board and i cant find where to jumper a new one in . .
CAN ANYONE HELP ME
thanks
bob |
Aussie Mobo-fu Master
Joined: 22 Nov 1999 Posts: 10244 Location: Mackay, Queensland, Australia
Posted: Sun Aug 15, 2004 8:48 am Post subject: |
Right next to the bios chip there's a little black box about an inch or so long and a half inch wide, that contains the battery and realtime clock.
Sometimes these are removeable and replaceable sometimes not, othertimes you can pop the lid off and find a standard coin cell battery inside which is replaceable.
I'm sure that it is possible to supply power to the CMOS by wiring a battery of suitable voltage to the CMOS clear jumper pins but I don't know enough about this to advise you.
Aussie _________________ Our lives begin to end the day we become silent about things that matter - Martin Luther King |
tedybear Black Belt 5th Degree
Joined: 14 Feb 2004 Posts: 7251 Location: Fulton, New York, on Earth
bobg831 Pilgrim
Posted: Sun Aug 15, 2004 10:07 am Post subject: CMOS Battery |
found a little black box 1.5 '' x .5 ''
says dallas real time clock
it was tied stripped down. looks like it,
have to buy new one
thank you !  |
Posted: Sun Aug 15, 2004 10:18 am Post subject: |
That's the one...Used to have to replace 'em on older CPU boards for work. If you need a hand finding one? Try a search using MCM electronics or ECG parts.
S- |
wiliamjack703 Pilgrim
Posted: Thu Aug 22, 2013 4:25 am Post subject: Re: CMOS Battery |
| bobg831 wrote: | I have an old biostar MB-8500tuc-a (ver3.2) Motherboard.
CAN ANYONE HELP ME
thanks
bob |
Hi bob, on the second speech, specifically are you looking for any spot to connecting the battery on the motherboard? |
evasive Mobo-fu Master
Joined: 06 May 2001 Posts: 36479 Location: Netherlands, Breda
Posted: Thu Aug 22, 2013 5:30 am Post subject: |
Nope, he has found he needs to replace the entire RTC/CMOS battery unit. They were made by DALLAS semiconductor. _________________ We hate rut, but we fear change.
Karlsweldt Enlightened Master
Posted: Thu Aug 22, 2013 10:08 am Post subject: |
Those older motherboards with the Dallas RTC design were doomed from the start. Most older motherboards did have two CMOS chips.. one for the "odd" registers, one for the "even" registers (0, 2, 4, 6 etc. are 'even'.. 1, 3, 5, 7 etc. are 'odd'). One of those chips had a battery and crystal as part of the makeup, in a larger case. There was no provision to apply an external power source to the real-time clock. If the Dallas RTC chip was in a socket, easy to replace. But too many motherboards had them soldered in. A bugger to replace! The original chip model was 1287 or 1287A.. the replacement is 12887A, if it can be found.
They are very hard to find today, especially in "new" condition. But there were several ingenious methods to replace the battery and revive the system. But you have to be very careful about doing surgery on the chip, as cutting into the leads for the RTC crystal is possible. Here is one method to revive the Dallas RTC feature. _________________ F@H.. to solve mankind's maladies.. in our lifetimes! |
