CPU overheating?
Goto page Previous  1, 2, 3, 4, 5, 6, 7, 8, 9, 10  Next
Post new topic   Reply to topic    The Mother Board Forum Index -> Cooling Tips and Tricks
ajmackdaddy
PostPosted: Mon Nov 10, 2003 10:07 pm    Post subject: Reply with quote
That's dumb. I don't have any experience with this thermal stuff, so if you guys have any tips please let me know. Also, if you know of any websites or anything with instructions that'd great. Especially pictures of application would help. I obviously don't want a busted processor and don't want to have to pay for another processor.
2.8 GHz P4 with HT
Gigabyte 8KNXP mobo
1 GB Kingston PC3200 with heat spreaders
ATI Radeon 9700 Pro retail
Western Digital 80 GB Caviar hard drive
Thermaltake Xaser III case w/420 W Thermaltake PSU
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger
Tolemac
PostPosted: Mon Nov 10, 2003 10:37 pm    Post subject: Reply with quote
There are some basic instructions in my Cooling 101 guide and more detailed instructions with pictures at Arctic Silver.
The main thing to remember is to make sure that the paste is about paper thin and that it covers the surface of the die completely. cool
The Gift of Healing
ajmackdaddy
PostPosted: Tue Nov 11, 2003 4:08 am    Post subject: Reply with quote
The surface of the die? What's that?
2.8 GHz P4 with HT
Gigabyte 8KNXP mobo
PostPosted: Tue Nov 11, 2003 4:48 am    Post subject: Reply with quote
The die is the metal plate on top of the P4, with a hole in one corner and the chips specs and serial no.s stamped on it. It is used to dissapate heat, but is not efficient enough, so you need a heatsink to aid this....
Quote:
Yep. I'm using the paste that came with the Thermaltake.
Why does it void the warranty on the CPU? Intel is crap
It is a get out clause on the CPU manufacturers behalf, however they will not honour warranty if they detect a different thermal compound from what they recommend - I have seen this first hand with AMD, yet they honour it with a blatantly cracked die? Go figure.... eek
The trees are bare and everywhere
The streets are full of strangers
~Les Miserables~
View user's profile Send private message Visit poster's website MSN Messenger
ajmackdaddy
PostPosted: Tue Nov 11, 2003 5:43 am    Post subject: Reply with quote
Do you want to cover up the hole you mentioned? I assume no, but one of my friends today told me that thermal compound is for covering small indentations between the CPU and heatsink.
So basically you want a very thin, round layer on the top of the CPU?
2.8 GHz P4 with HT
Gigabyte 8KNXP mobo
charibdis
PostPosted: Tue Nov 11, 2003 1:03 pm    Post subject: Reply with quote
As Tolemac said:
Try not to make it rounded. As for the little hole in the CPU I have no idea on that one. I'm an AMD man myself.
View user's profile Send private message AIM Address MSN Messenger
Tolemac
PostPosted: Tue Nov 11, 2003 2:57 pm    Post subject: Reply with quote
If you follow the instructions on the Arctic Silver page for P4s, then you'll be right and you won't have to worry about the hole. Personally, I smooth it over the entire heat spreader on P4s and very little paste goes into the hole. cool
The Gift of Healing
ajmackdaddy
PostPosted: Tue Nov 11, 2003 5:18 pm    Post subject: Reply with quote
Ok. I'll try to have one of my friends over and see if he can help me. He has a little more experience with this stuff.
2.8 GHz P4 with HT
Gigabyte 8KNXP mobo
Tulatin
PostPosted: Tue Nov 11, 2003 5:29 pm    Post subject: Reply with quote
The little hole it to let air in/out to deal with the pressure of the heatsink. However, the slits under the spreader do that well enough, so don't worry.
gnelso
PostPosted: Tue Nov 11, 2003 5:38 pm    Post subject: Reply with quote
ajmackdaddy wrote:
I didn't use any thermal paste on it. I just used whatever Intel put on the heatsink (some tape or something).
I also already bought another heatsink...it's gonna be here today. It comes with its own thermal paste that I'll use. I've never heard of those voiding the warranty...that doesn't make any sense.
The tape that I think your referring too, is just used during shipping, and must be removed and thermal paste applied before application, If you did what I think, that would explain the probs.
\_ cool _/
Post new topic   Reply to topic    The Mother Board Forum Index -> Cooling Tips and Tricks All times are GMT - 8 Hours
Page 9 of 10
