folding at home server error codes
Postby len444 » Sun Oct 05, 2003 11:05 am
J.C.GARCIA wrote:so am i . for a moment i thought i had lost it . i will be monitoring the times taken and compare them against some info i have which i jotted down from when i used the 3.24 version . i will also compare them against my sons pc which uses 3.24 and the same flags . once again thanks :wink:
what are the system spec's of your sons pc? if there are sse instruction sets on the cpu, then it'll make sense to upgrade to the 3.25beta on his comp as well. i suppose watch the comp (and server error codes which this thread is supposed to be about- :P ). add the gain in performance of your son's pc w/ the 3.25beta to the gain of yours, and you'll be climbing the charts! now if you'ld let the pc autodial the modem- check the "connections" (folding forum) thread as it deals w/ modem configuration. 5hrs of crunch time is a lot of time to be wasted while idle...
len444
Postby J.C.GARCIA » Sun Oct 05, 2003 7:09 pm
my sons pc is the same specs as mine , see signature . i have gained absolutely no perforamnce gain . it is doing the frames slower than my sons . my sons uses the3.24 graphical with flags advmethods forceasm . i'll give you an example . we are both doing the same wu p571
son (A) 8min 40secs per frame using 3.24 graphical with flags stated above
me (B) 10min per frame using 3.25 beta with flags stated above
:!: :!: :!: :!: any clues . i suppose i could go back to the 3.24
p4 2.4b 533mhz fsb
epox 4bea2
768mb ddr pc2100
radeon 7000 64mb w/tv out
live 1024
dvdrw lg gsa 4040b
cdrw btc 48x16x48x
xp home
J.C.GARCIA
Postby len444 » Sun Oct 05, 2003 7:19 pm
J.C.GARCIA wrote:my sons pc is the same specs as mine , see signature . i have gained absolutely no perforamnce gain . it is doing the frames slower than my sons . my sons uses the3.24 graphical with flags advmethods forceasm . i'll give you an example . we are both doing the same wu p571
don't go back to the 3.24! first off, if you paused/ quit, and restarted the client, you would see that the rate it crunches at varies each time this is done! perhaps you haven't added the flags correctly? add the -verbosity 9 flag as well for increased output to the fahlog.txt file. what does it currently state in the fahlog file for your comp at the initialization point for this #571 wu? does it state the flags, or is there an error like "unrecognized flag"- is there an "extra sse speed boost ok" stated?
len444
Postby J.C.GARCIA » Sun Oct 05, 2003 7:31 pm
[16:38:03] Folding@home Gromacs Core
[16:38:03] Version 1.51 (September 25, 2003)
[16:38:03]
[16:38:03] Preparing to commence simulation
[16:38:03] - Looking at optimizations...
[16:38:03] - Created dyn
[16:38:03] - Files status OK
[16:38:03] - Go method
[16:38:04] - Expanded 542573 -> 3588921 (decompressed 661.4 percent)
[16:38:04] - Starting from initial work packet
[16:38:04]
[16:38:04] Project: 571 (Run 11, Clone 437, Gen 9)
[16:38:04]
[16:38:04] Assembly optimizations on if available.
[16:38:04] Entering M.D.
[16:38:25] Protein: p571_L939_K12M_nat
[16:38:25]
[16:38:25] Writing local files
[16:38:25] Extra SSE boost OK.
[16:38:30] Writing local files
[16:38:30] Completed 0 out of 500000 steps (0)
[16:48:26] Writing local files
[16:48:26] Completed 5000 out of 500000 steps (1)
[16:58:22] Writing local files
[16:58:22] Completed 10000 out of 500000 steps (2)
[17:08:17] Writing local files
p4 2.4b 533mhz fsb
epox 4bea2
768mb ddr pc2100
live 1024
dvdrw lg gsa 4040b
cdrw btc 48x16x48x
xp home
J.C.GARCIA
Postby J.C.GARCIA » Sun Oct 05, 2003 7:36 pm
i'll add the -verbosit 9 flag to get extra info . it should look like this
"C:\Program Files\Folding@Home\winFAH.EXE" -advmethods -forceasm -verbosity 9 right :?: . to add that extra flag do i puase quit then add flag then restart it :?:
p4 2.4b 533mhz fsb
epox 4bea2
768mb ddr pc2100
live 1024
dvdrw lg gsa 4040b
cdrw btc 48x16x48x
xp home
J.C.GARCIA
Postby len444 » Sun Oct 05, 2003 8:00 pm
J.C.GARCIA wrote:i'll add the -verbosity 9 flag to get extra info . it should look like this
pause, quit, add flag(s), select apply, close window, then restart.
len444
Postby J.C.GARCIA » Sun Oct 05, 2003 8:19 pm
ok added and wu started . i'll have to wait for the next wu to get more info .
p4 2.4b 533mhz fsb
epox 4bea2
768mb ddr pc2100
live 1024
dvdrw lg gsa 4040b
cdrw btc 48x16x48x
xp home
J.C.GARCIA
Postby J.C.GARCIA » Sun Oct 05, 2003 8:21 pm
here is the extra info after i started the wu
Folding@home Client Version 3.25
http://foldingathome.stanford.edu
email:help@foldingathome.stanford.edu
Arguments: -advmethods -forceasm -verbosity 9
[23:30:01] - Ask before connecting: Yes
[23:30:01] - Use IE connection settings: Yes
[23:30:01] - User name: J.C.GARCIA (Team 33258)
[23:30:01] - User ID = 4EB610EE4B664297
[23:30:01] - Machine ID: 1
[23:30:01]
[23:30:01] Loaded queue successfully.
[23:30:01] Initialization complete
[23:30:01] + Benchmarking ...
[23:30:04] The benchmark result is 5720
[23:30:04]
[23:30:04] + Processing work unit
[23:30:04] Core required: FahCore_78.exe
[23:30:04] Core found.
[23:30:04] Working on Unit 09 [October 5 23:30:04]
[23:30:04] + Working ...
[23:30:04] - Calling 'FahCore_78.exe -dir work/ -suffix 09 -forceasm -lifeline 2464
[23:30:04]
[23:30:04] *------------------------------*
[23:30:04] Folding@home Gromacs Core
[23:30:04] Version 1.51 (September 25, 2003)
[23:30:04]
[23:30:04] Preparing to commence simulation
[23:30:04] - Assembly optimizations manually forced on.
[23:30:04] - Not checking prior termination.
[23:30:04] - Go method
[23:30:05] - Expanded 542573 -> 3588921 (decompressed 661.4 percent)
[23:30:05]
[23:30:05] Project: 571 (Run 11, Clone 437, Gen 9)
[23:30:05]
[23:30:05] Assembly optimizations on if available.
[23:30:05] Entering M.D.
[23:30:44] (Starting from checkpoint)
[23:30:44] Protein: p571_L939_K12M_nat
[23:30:44]
[23:30:44] Writing local files
[23:30:44] Completed 175000 out of 500000 steps (35)
[23:30:44] Extra SSE boost OK.
p4 2.4b 533mhz fsb
epox 4bea2
768mb ddr pc2100
live 1024
dvdrw lg gsa 4040b
cdrw btc 48x16x48x
xp home
J.C.GARCIA
Postby len444 » Sun Oct 05, 2003 8:39 pm
looks ok to me. time to let it crunch away!
btw, are you stopping FAH each day for maintenance? the reason i ask, is the 3.24 client will run the -forceasm for the first wu worked on, and at each client restart. only time that 3.25beta will outperform the 3.24 version is when it's left to crunch away w/ o closing FAH, and left to automatically send, and fetch wu's. this would then be the place that the 3.25beta version will outperform the 3.24 version due to the -forceasm flag sticking w/ the 3.25beta, and not w/ the 3.24 version (for each new wu fetched). perhaps you should consider letting the modem automatically establish a connection, and let the disconnect if inactive duration time out for a disconnect? 5 hrs is a huge chunk of time for a comp to sit idle you know!?!
len444
Postby J.C.GARCIA » Sun Oct 05, 2003 8:51 pm
ok i'll do one thing . before the wu finishes i'll connect and when the dialogue box comes out saying ready to connect i'll click it right away . by the way my sons pc is configured also like mine . to ask before connecting :!:
p4 2.4b 533mhz fsb
epox 4bea2
768mb ddr pc2100
live 1024
dvdrw lg gsa 4040b
cdrw btc 48x16x48x
xp home
J.C.GARCIA
PreviousNext
Users browsing this forum: Yahoo [Bot] and 0 guests
