Athlon processor specifications, settings & information.
Goto page 1, 2, 3, 4, 5, 6  Next
Post new topic   Reply to topic    The Mother Board Forum Index -> General
Aussie
PostPosted: Wed Sep 10, 2003 1:19 pm    Post subject: Athlon processor specifications, settings & information. Reply with quote
Athlon Thunderbird 1333MHz 133FSB 10.0x Multi 1.75volts (A1333AMS3C)
Athlon Thunderbird 1400MHz 133FSB 10.5x Multi 1.75volts (A1400AMS3C)
Athlon XP 1500+ Palomino 1333MHz 133FSB 10.0x Multi 1.75 volts (AX1500DMT3C)
Athlon XP 1600+ Palomino 1400MHz 133FSB 10.5x Multi 1.75 volts (AX1600DMT3C)
Athlon XP 1700+ Palomino 1467MHz 133FSB 11.0x Multi 1.75 volts (AX1700DMT3C)
Athlon XP 1800+ Palomino 1533MHz 133FSB 11.5x Multi 1.75 volts (AX1800DMT3C)
Athlon XP 1900+ Palomino 1600MHz 133FSB 12.0x Multi 1.75 volts (AX1900DMT3C)
Athlon XP 2000+ Palomino 1667MHz 133FSB 12.5x Multi 1.75 volts (AX2000DMT3C)
Athlon XP 2100+ Palomino 1733MHz 133FSB 13.0x Multi 1.75 volts (AX2100DMT3C)
Athlon XP 1700+ Thoroughbred A 1466MHz 133FSB 11.0x Multi 1.50 volts (AXDA1700DLT3C)
Athlon XP 1800+ Thoroughbred A 1533MHz 133FSB 11.5x Multi 1.50 volts (AXDA1800DLT3C)
Athlon XP 1900+ Thoroughbred A 1600MHz 133FSB 12.0x Multi 1.50 volts (AXDA1900DLT3C)
Athlon XP 2000+ Thoroughbred A 1666MHz 133FSB 12.5x Multi 1.60 volts (AXDA2000DUT3C)
Athlon XP 2100+ Thoroughbred A 1733MHz 133FSB 13.0x Multi 1.60 volts (AXDA2100DUT3C)*
Athlon XP 2200+ Thoroughbred A 1800MHz 133FSB 13.5x Multi 1.65 volts (AXDA2200DKV3C)
Athlon XP 1600+ Thoroughbred B 1400MHz 133FSB 10.5x Multi 1.60 volts (AXDA1600DUT3C)
Athlon XP 1700+ Thoroughbred B 1466MHz 133FSB 11.0x Multi 1.50 volts (AXDA1700DUT3C)
Athlon XP 1800+ Thoroughbred B 1533MHz 133FSB 11.5x Multi 1.50 volts (AXDA1800DUT3C)
Athlon XP 1900+ Thoroughbred B 1600MHz 133FSB 12.0x Multi 1.50 volts (AXDA1900DUT3C)
Athlon XP 2000+ Thoroughbred B 1666MHz 133FSB 12.5x Multi 1.60 volts (AXDA2000DUT3C)*
Athlon XP 2100+ Thoroughbred B 1733MHz 133FSB 13.0x Multi 1.60 volts (AXDA2100DUT3C)*
Athlon XP 2200+ Thoroughbred B 1800MHz 133FSB 13.5x Multi 1.60 volts (AXDA2200DUV3C)
Athlon XP 2400+ Thoroughbred B 2000MHz 133FSB 15.0x Multi 1.65 volts (AXDA2400DKV3C)
Athlon XP 2400+ Thoroughbred B 2000MHz 133FSB 15.0x Multi 1.60 volts (AXDA2400DUV3C)
Athlon XP 2600+ Thoroughbred B 2133MHz 133FSB 16.0x Multi 1.65 volts (AXDA2600DKV3C)
Athlon XP 2600+ Thoroughbred B 2083MHz 166FSB 12.5x Multi 1.65 volts (AXDA2600DKV3D)
Athlon XP 2700+ Thoroughbred B 2166MHz 166FSB 13.0x Multi 1.65 volts (AXDA2700DKV3D)
Athlon XP 2800+ Thoroughbred B 2250MHz 166FSB 13.5x Multi 1.65 volts (AXDA2800DKV3D)
Athlon XP 2500+ Barton 1833MHz 166FSB 11.0x Multi 1.65 volts (AXDA2500DKV4D)
Athlon XP 2600+ Barton 1917MHz 166FSB 11.5x Multi 1.65 volts (AXDA2600DKV4D)
Athlon XP 2800+ Barton 2083MHz 166FSB 12.5x Multi 1.65 volts (AXDA2800DKV4D)
Athlon XP 3000+ Barton 2167MHz 166FSB 13.0x Multi 1.65 volts (AXDA3000DKV4D)
Athlon XP 3000+ Barton 2100MHz 200FSB 10.5x Multi 1.65 volts (AXDA3000DKV4E)
Athlon XP 3200+ Barton 2200MHz 200FSB 11.0x Multi 1.65 volts (AXDA3200DKV4E)
*This code is used on both Thoroughbred A's and Thoroughbred B's, the only way to tell the difference between the two is by the stepping code. All Thoroughbred A's have a stepping code which ends in A, like AIUGA. All Thoroughbredred B's have a stepping code which ends in B, like AIUGB.
AMD Sempron Processors - Socket A
SDA3000DUT4D 3000+ 2000MHz 12x Multi 1.60V 90º C 512KB 333MHz FSB OPGA
SDC2800DUT3D 2800+ 2000MHz 12x Multi 1.60V 90º C 256KB 333MHz FSB OPGA
SDA2800DUT3D 2800+ 2000MHz 12x Multi 1.60V 90º C 256KB 333MHz FSB OPGA
SDA2600DUT3D 2600+ 1833MHz 11x Multi 1.60V 90º C 256KB 333MHz FSB OPGA
SDA2500DUT3D 2500+ 1750MHz 10.5x Multi 1.60V 90º C 256KB 333MHz FSB OPGA
SDA2400DUT3D 2400+ 1667MHz 10x Multi 1.60V 90º C 256KB 333MHz FSB OPGA
SDA2300DUT3D 2300+ 1583MHz 9.5x Multi 1.60V 90º C 256KB 333MHz FSB OPGA
SDC2200DUT3D 2200+ 1500MHz 9x Multi 1.60V 90º C 256KB 333MHz FSB OPGA
SDA2200DUT3D 2200+ 1500MHz 9x Multi 1.60V 90º C 256KB 333MHz FSB OPGA
AMD Sempron Processors - Socket 754
SDA3100AIP3AX 3100+ 1800MHz 1.40V 70º C 256KB 754-Pin OμPGA
Opteron specs.
http://139.95.253.213/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=45,E=0000000000168869532,K=1671,Sxi=1,Solution=4343
Athlon 64 specs.
http://139.95.253.213/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=86,E=0000000000168868933,K=1671,Sxi=1,Solution=4273
AthlonXP specs.
http://139.95.253.213/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=26,E=0000000000168869092,K=1671,Sxi=1,Solution=3913
AthlonMP specs.
http://139.95.253.213/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=44,E=0000000000168869163,K=1671,Sxi=1,Solution=4196
Athlon (classic) specs.
http://139.95.253.213/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=69,E=0000000000168869262,K=1671,Sxi=1,Solution=117
655 different processors detailed!
http://www.geek.com/procspec/procspec.htm
AMD64 OPN's
http://www.amdboard.com/amd64_opn.html
If you can see any errors or omissions or if you have anything to add to this information please post your comments below and I will edit this as necessary.
EDIT: Off-site links added 21-07-04.
Aussie
Dmashl
PostPosted: Wed Sep 10, 2003 1:27 pm    Post subject: Reply with quote
should make this a sticky. very useful, get a lot of people not knowing what fsb to run their CPU at.
smile, it makes people wonder what you're up to
View user's profile Send private message Send e-mail
PostPosted: Wed Sep 10, 2003 1:59 pm    Post subject: Reply with quote
Finally all of them together in one easy readable list. Good work Aussie cool
speedblurr
PostPosted: Wed Sep 10, 2003 4:29 pm    Post subject: Reply with quote
Thanks Aussie, your services are much appreciated!!
View user's profile Send private message Send e-mail AIM Address
S.D.Willie
PostPosted: Wed Sep 10, 2003 10:57 pm    Post subject: Reply with quote
very cool. wish i saw this the other day b4 i broke out my calculator.
snakebite66
PostPosted: Fri Sep 19, 2003 1:09 pm    Post subject: Reply with quote
I went into my bios and checked I had similar settings, I did except a few littel exceptions, though the mobo auto detects that I have a 2700+.
Slight variance, Not being the complete expert, does it matter?
Benjamin Franklin (1706-1790)
Aussie
PostPosted: Fri Sep 19, 2003 1:27 pm    Post subject: Reply with quote
In a word no.
Very slight variances are to be expected in FSB/CPU speed and Vcore voltage at default settings.
There should be no variance at all in multiplier unless the CPU is wrongly configured or the user has manually adjusted the multiplier.
There should be no major variance in FSB/CPU speed unless the CPU is wrongly configured or the user has manually adjusted the FSB and/or multiplier.
There should be no major variance in Vcore voltage unless the CPU is wrongly configured or the user has manually adjusted the Vcore voltage.
Manual adjustment of CPU configuration parameters is generally used when overclocking.
Aussie
robneilz
PostPosted: Sat Sep 20, 2003 5:35 am    Post subject: Reply with quote
how do I tell what type of processor I have. All I know is that mine is a AMD 1800+XP
View user's profile Send private message MSN Messenger
FatMikel
PostPosted: Sat Sep 20, 2003 5:54 am    Post subject: Reply with quote
download Sisandra Software.. it should tell you which make it is... ( TBRED A, B etc )
PostPosted: Sat Sep 20, 2003 12:39 pm    Post subject: Reply with quote
Had one Athlon spec sheet in french, but it was more complicated...
Post new topic   Reply to topic    The Mother Board Forum Index -> General All times are GMT - 8 Hours
Page 1 of 6
