It is currently Tue Jan 22, 2019 9:08 am
 Post subject: slight problem w/ wu's
PostPosted: Mon Sep 08, 2003 8:05 pm
Lately I have been noticing that on my computer F@H keeps wqanting to connect to get more WU's. no biggie except that it wqant to dend data and get a new unit after only doing a 10-15% on a 250 or bigger WU.
I can sit here and watch it get to about 23/400 then say thats it need to connect to send data and get new WU. then it will download new WU then want to connect again for another one with in minutes. so far this has done it on both versions 3.24 and 3.25, graphic and console, have also reinstall and with same results. Does anybody have any idea what is going on. if it counted on the scopre it would be no biggie but all it does is add to my total amout of WU's and my score stay the same :(
4 gigs ram
2 250 gig samsung sata HDs
2 lite on sata dvd burners
PostPosted: Mon Sep 08, 2003 8:48 pm
are you overclocking?
PostPosted: Mon Sep 08, 2003 10:07 pm
yeah but not much xp2000+ oc'd to 1.76Ghz (133FSB-->141FSB)
Is that the cause b/c now that you mention it once i started to bump up the FSB over 140 this started to happen and win xp started to become unstable at 145FSB
4 gigs ram
PostPosted: Mon Sep 08, 2003 10:18 pm
Hmmm. are you getting a different work unit or the same one every time? My folding is really weird - it resets, sends, gets, new WU... and i try deleting all the wu data - it goes and gets the same 1 again...
PostPosted: Mon Sep 08, 2003 11:05 pm
if the system becomes unstable , then reducing the OC slightly might help. also consider what type of memory is being used, and what memory timings are being used. if running at a faster cas setting (lower#), then set that back to spec rating. i don't OC currently, but i run stock cas setting w/ aggressive memory timings. you should check out the bios forum, as there is an optimization sticky that has some good links in it. clean up/ tweak your bios, and that might make the difference.
PostPosted: Mon Sep 08, 2003 11:17 pm
the protein# is the same, but will be at a slightly different stage of the folding process. i think i've seen that they are just giving out only 1 copy of each protein at first, and then they analyze what they get/ don't get back, and reissue only then. so if things crap out, and you get a new WU w/ the same protein#, it will be different.
PostPosted: Tue Sep 09, 2003 1:37 am
Quote:
As far as i can tell different WU's. One will be 400 the next 500 then maybe a 250...Always changing
Quote:
Checked posts cleaned and tweaked both bios and windows and its still gets unstable.. going to try some better ram some time this month (using PNY now)
4 gigs ram
PostPosted: Tue Sep 09, 2003 1:52 am
Just notice the size of my current WU. Looks like I got one of those nice 2500 suckers. This would not be a good time for my system to act up since this WU should give a nice score. Can you back up data from WU and restore them?
4 gigs ram
PostPosted: Tue Sep 09, 2003 4:05 am
I was passed this tip from someone else. In the folder that F@H is in you will find a folder called 'Work'. This contains details of your current WU and progress. Copy this somewhere else and if folding should fail copy the folder back, opting to overwrite everything. I don't know if this works, been trouble free for a while, but it's all I can suggest.
PostPosted: Tue Sep 09, 2003 6:05 pm
Those 2500s are all i've been getting ,worth a nice 50 points a pop, and are just 100 framers in disguise. Now, as to ocing causing folding istability - iif i push it to 2.7, it rips thru, but freezes... i don't know if the work is lost, so i just stuck with a safe 2.5
