In case you mind ...
Postby Tulatin » Fri Sep 05, 2003 11:26 pm
Join request made and approved - i can also add you via a tool you know... just ask now (PM or Post) and i'll throw you in.
Tulatin
Postby cazador » Fri Sep 05, 2003 11:30 pm
lol..cool... thxs for the help...
Asus A7N8X Deluxe V2.0
Athlon Xp 2500+ @ 2200 mhz (XP3200+)
Ati 9600 128 Mb @ 450/250
512 mb PC 3200 Mushkin Level II
Seagate Barracuda SATA 7200.7 80gb
Seagate Barracuda ATA IV 7200rpm 40gb
cazador
Postby cazador » Fri Sep 05, 2003 11:31 pm
I would like to know if there is a way to optimize .. F@H....
any special setting of something?
cazador
Postby Tulatin » Fri Sep 05, 2003 11:33 pm
take a look round the folding@ home forum. THe info on switches can be found there, or in the faq at the team site (click the link in my sig)
Tulatin
Postby cazador » Sat Sep 06, 2003 5:20 pm
something wrong with F@H...
it was almost done the workunit.. .. I close program..
I did run .. Adware 6.0 clean some adware on pc.. them shut donw PC>.
when I started it this morning.. and when to run F@H .. it reset back to
0 % ..... it isnt a diffrennt workunit... just the same back from the beginning..
cazador
Postby Tulatin » Sat Sep 06, 2003 5:40 pm
That's a pain - try pausing folding before shutting it off... other than that, we're still looking for a fix.
Tulatin
Postby son0rous » Sat Sep 06, 2003 11:12 pm
look closely as what ad aware is removing, 10 bucks says one called "wudata". It picks it up as a useless file and deletes it. I think it contains info about your work unit and when you delete and restart it forgets what it was doin
son0rous
Postby gnelso » Sun Sep 07, 2003 12:08 am
I'm not a F@H member because I don't have online service to my pc.
But I'll agree, working at night sucks, I worked on nights for 2yrs
I'll join eventually when I can.
\_ 8) _/
gnelso
Postby Ladd » Sun Sep 07, 2003 7:10 am
to help with the disappearing work units after shut down, I made a folder in my F@H folder called backed up work. Before I shut down I copy my work folder and paste it in there. Then when It resets the next day, I just replace my work folder with the one i backed up last night. It worked twice so far for me. Hope that helps.
Ladd
Postby Ripshod » Sun Sep 07, 2003 7:27 am
Thanks for the tip L, was having problems myself so I have been folding 24/7 for a few days now. I'll try your tip (at last I might be able to do some maintainance, got a dodgey HD to swap).
Ripshod
PreviousNext
Users browsing this forum: DotBot [Bot] and 0 guests
