miki02131 Black Belt 2nd Degree
Joined: 26 Feb 2003 Posts: 2161 Location: Newport, Rhode Island USA
Posted: Fri Sep 05, 2003 2:52 pm Post subject: No Luck Installing Client Soft on Longhorn |
I have a test partition with LH4015. Today, I tried to install the client F@H software on it to no avail. I know the software is compatible with XP, I can't understand why it wouldn't install on LH since LH is built right on top of XP. Any idea? _________________ Help humanity .....join the
Motherboards.org
folding team! 33258
J.C.GARCIA Black Belt 3rd Degree
Joined: 22 Aug 2001 Posts: 3707 Location: Great Beer Zone
Posted: Fri Sep 05, 2003 2:57 pm Post subject: |
compatibilty issues maybe  _________________ p4 2.4b 533mhz fsb
epox 4bea2
768mb ddr pc2100
radeon 7000 64mb w/tv out
live 1024
dvdrw lg gsa 4040b
cdrw btc 48x16x48x
xp home |
Posted: Fri Sep 05, 2003 2:58 pm Post subject: |
did you run it from a cd . if so run it from the hard drive _________________ p4 2.4b 533mhz fsb
epox 4bea2
768mb ddr pc2100
live 1024
dvdrw lg gsa 4040b
cdrw btc 48x16x48x
xp home |
DefaultDave Brown Belt
Posted: Fri Sep 05, 2003 3:26 pm Post subject: |
there must be some differences though. i mean Win2000, and WinXP are built on NT technoligy and stuff work on one OS but not the other so have one built from the code base of enouther doens't garrentee it will work.
if you can't get the graphic client to work i'd install the console version. i'd bet that'll run on it. _________________ Default_Dave's STATS! Team #33258 |
Posted: Fri Sep 05, 2003 3:47 pm Post subject: |
could it be the new file system that longhorn uses  _________________ p4 2.4b 533mhz fsb
epox 4bea2
768mb ddr pc2100
live 1024
dvdrw lg gsa 4040b
cdrw btc 48x16x48x
xp home |
Posted: Fri Sep 05, 2003 4:18 pm Post subject: |
miki what kind of errors are you getting  _________________ p4 2.4b 533mhz fsb
epox 4bea2
768mb ddr pc2100
live 1024
dvdrw lg gsa 4040b
cdrw btc 48x16x48x
xp home |
Posted: Fri Sep 05, 2003 4:28 pm Post subject: |
miki this is from the folding website
| Quote: | If you are attempting to install the Windows graphical client or screen saver, and see "Setup is starting..." pop up, but then nothing else happen (no error message even), the problem is likely due to the presence of files named "setup.exe" in some directory present in your path (likely culprits are the directory in which the F@h installer is, your Desktop, and your temp directory). Remember that you may have multiple temp directories, depending on your operating system. Delete or move the setup.exe files and all should work fine.
dont know if this will help you _________________ p4 2.4b 533mhz fsb
epox 4bea2
768mb ddr pc2100
live 1024
dvdrw lg gsa 4040b
cdrw btc 48x16x48x
xp home |
Posted: Fri Sep 05, 2003 8:42 pm Post subject: |
I got an error message saying that the software is not compatible with the OS. _________________ Help humanity .....join the
Motherboards.org
folding team! 33258
evasive Mobo-fu Master
Joined: 06 May 2001 Posts: 36410 Location: Netherlands, Breda
Posted: Fri Sep 05, 2003 8:49 pm Post subject: |
email professor Pande... _________________ We hate rut, but we fear change.
