Don't log off!!!
Postby Tulatin » Wed Sep 03, 2003 8:28 pm
Well Len, according to the changelog for 3.25 beta, sse is applied to tinkers.
Tulatin
Postby len444 » Wed Sep 03, 2003 9:59 pm
Tulatin wrote:Well Len, according to the changelog for 3.25 beta, sse is applied to tinkers.
here's the change log:
http://www.stanford.edu/group/pandegrou ... hanges.txt
    Folding@Home 3.25 beta
    May 7, 2003
    THIS BETA WILL NOT EXPIRE.
    RECENT CHANGES (Client) - from 3.24 Release:
    3.25 beta (unmarked)
    - If -forceasm is used, then on every execution of the core until the
    client is restarted, SSE optimizations will be used if possible (if
    the chip is an AMD chip, then be default, without the flag, it would
    not be chosen over 3DNow). Prior to this client, this effect would have
    held true only for the first work unit run after starting the client.
where does it say tinker?
len444
Postby Tulatin » Wed Sep 03, 2003 10:01 pm
Alright. I misunderstood. However, tinker work units DID recieve a nice performance boost, as did grommacks ones.
Tulatin
Postby son0rous » Wed Sep 03, 2003 10:08 pm
i could of swore i saw a mod at the F@H forum say that the new one had sse optimizations for tinkers, or at least some other type of optimization
son0rous
Postby Tulatin » Wed Sep 03, 2003 10:09 pm
Unfortunately it doesn't, but it does boost the performance.
Tulatin
Postby Ladd » Wed Sep 03, 2003 10:18 pm
Brutal, that disappearing thing never happened to me before.... until I shutdown last night. I had a 70 pointer at 88% and it just was gone this morning when I turned the computer back on.... :(
Im gonna start backing up my work folder before I shut down at night. I wonder why it does that? Thats the first time its done it to me since I started folding.
Ladd
Postby Tulatin » Wed Sep 03, 2003 10:19 pm
Yeah, i had the same thing happen when windows crashed at 75/2500 earlier.... i think folding caused the crash (cpu choked due to lack fo cycles), so that's why.
Tulatin
Postby son0rous » Wed Sep 03, 2003 10:24 pm
the client backs up itself at specific frame/step incriments, i'm thinkin maybe if you shut down your computer just when it is backing up maybe it forgets where it left off? just a hypothesis
son0rous
Postby Tulatin » Wed Sep 03, 2003 10:25 pm
What are these backing up intervals, and any chajce of diggin up a way to shorten the mfrom the net?
Tulatin
Postby len444 » Thu Sep 04, 2003 12:00 am
Tulatin wrote:What are these backing up intervals, and any chajce of diggin up a way to shorten the mfrom the net?
it's called check pointing (saving to disk). i think tinker WU will save to disk w/ each frame, and gromacs will save at each % completion increment. a gah WU will do 30 steps (from what i've seen), and check pointing only occurs at 100% completion of each step. not sure about check pointing between intervals. i know i've seen this topic at the FAH forum- more than likely a feature request. check pointing, gromac check pointing tinker check pointing- try those searches at the FAH forum:
http://forum.folding-community.org/
len444
PreviousNext
