Don't log off!!!
Postby son0rous » Tue Sep 02, 2003 4:14 pm
maybe they made some minor tweaks to how it is displayed, the 100/400 shows the frames and when it says writing to disk it is doing sort of a backup so when you restart it knows where it left off
son0rous
Postby len444 » Tue Sep 02, 2003 9:23 pm
Default_Dave wrote:got a question too...i used to see the "frame 01...02...03...ect" in the console version...now i get the Step 01 "writing to hd" (or whatever it says) with the 100 out of 400 and so on ... no more frame references.
what's the deal? is this from the -advmethods or -forceasm ? or is it cuase of the -local switch? just curious...all's running.
frames= Tinker WU, and steps= Gromacs WU. -advmethods flag will get a higher concentration of gromacs wu's, and -forceasm will give an extra sse boost (might equal 20% faster) specific to gromacs WU's.
len444
Postby Tulatin » Tue Sep 02, 2003 9:40 pm
len444 wrote:-forceasm will give an extra sse boost (might equal 20% faster) specific to gromacs WU's.
NOw applies to tinker work units, care of Beta 3.25
Tulatin
Postby Ripshod » Wed Sep 03, 2003 4:27 am
NTFS. I know, but it suits my needs better. You thinking this is the cause?
Ripshod
Postby len444 » Wed Sep 03, 2003 9:50 am
Ripshod wrote:NTFS. I know, but it suits my needs better. You thinking this is the cause?
no, not ntfs. i was contemplating if you had a large fat32 partition (over 32gig), and was loosing stability due to cluster size being too large for the data being written to it. but this doesn't appear to be the case.
len444
Postby len444 » Wed Sep 03, 2003 9:52 am
according to this reply at FAH forum, Tinker isn't using sse instruction sets.
len444
Postby Ripshod » Wed Sep 03, 2003 1:38 pm
Just completed my first WU. #349 in just under 26hrs. Must have been a stinker cos I've just gone to #22 in the team rankings.
Good to be working now. :lol:
Ripshod
Postby Ripshod » Wed Sep 03, 2003 1:46 pm
It doesn't make any sense not to optimise some code for SSE and SSE2 instructions seeing as the command line version (3.25) has optimisations for 3DNOW! Or could I be wrong?
Ripshod
Postby J.C.GARCIA » Wed Sep 03, 2003 1:48 pm
that's nice ripshod . roll away those wu's :wink:
p4 2.4b 533mhz fsb
epox 4bea2
768mb ddr pc2100
radeon 7000 64mb w/tv out
live 1024
dvdrw lg gsa 4040b
cdrw btc 48x16x48x
xp home
J.C.GARCIA
Postby len444 » Wed Sep 03, 2003 7:31 pm
Ripshod wrote:It doesn't make any sense not to optimise some code for SSE and SSE2 instructions seeing as the command line version (3.25) has optimisations for 3DNOW! Or could I be wrong?
i didn't right the code. tinker doesn't use sse, and gromacs does. tinker is supposed to be very easy to manipulate for the task at hand. gromacs are nice as they are written for speed.
btw, if you see 3dnow! stated in the console when you first start it up, you more than likely have a gromacs WU, which means that you should try and add the -forceasm flag. that will show "extra sse boost ok". just be sure to use ctrl -c to close the console properly (if and when you do).
len444
PreviousNext
Users browsing this forum: Yahoo [Bot] and 0 guests
