Collected Links : Virus/Spyware Information/Removal
Help and Discussion
Post Reply
Denniss
Contact:
Post by Denniss »
There are some very dangerous Viruses spreading out in the net (Bugbear / Sobig / W32Blast + variants and more) often using known Security leaks/issues within IE/Outlook or Windows
Please use Windowsupdate to get the most recent Security fixes for Windoze/IE/Outlook !
Use Auto/Liveupdate to update your Antivirusprogram/Firewall with the latest Patches/Upgrades/Virus Signature(Pattern) files !
->> Please do this frequently - at least once per week !!!
On infected systems it's possible Firewalls/Antivirusprograms are prevented from running or re-installing - some Viruses/Worms recognize and disable or bypass them !
Recently discovered Virus Threats + Virus Info:
Symantec - Bitdefender - Mcafee/Network Associates - Trendmicro - Panda
Antivirussoftware (Scanner + Removal tools + Signature/Pattern files) : Spyware/Adware/Malware/Dialer Removal : Alternative/Secure Internet-Browsers :
Opera - Mozilla
Mozilla Firefox - Mozilla Stand-Alone Browser
Mozilla Thunderbird - Mozilla Stand-Alone Mail
-> Malware programs like Dialer/Hijacker/etc do easily self-install with IE/Outlook due to their ActiveX/Active Scripting "Features" - with Mozilla/Opera these problems are reduced to near zero
Firewalls (free for private use) :
Kerio - Zonealarm - Outpost
ZoneAlarm Link Fixed - Toby B.
[url=http://www.motherboards.org/forums/viewtopic.php?t=26326][size=150]Collected Links against Virus/Spyware and other Malware[/size][/url]
[url=http://www.rhcf.com]Rebels Haven Computer Forum[/url]
Giggz
Contact:
Post by Giggz »
thnx for the addys and the info
Win Xp Pro Sp1
Intel Pentium 3
64meg of SD Ram
Geforce 4 Mx440 (64mb on board)
5.1 channel soundcard
Dvd Drive 16x
Lite on 32x12x40x rewriter
15" TFT Monitor
Toby B.
Contact:
Post by Toby B. »
Yes Denniss, Thanks for the info. I have made this one a sticky (at least for now anyway)....It deserves attention. :wink:
Denniss
Contact:
Post by Denniss »
It's alway good to have some links to removal programs on hand ....
KaosKid
Post by KaosKid »
3 Cheers for Denniss! I already had AdawarePro6, but this Spybot adds to it. Between the two of them, I think that every base is covered. Thanks for sharing.
[url=http://www.heatware.com/eval.php?id=19000/]HEATWARE[/url]
Denniss
Contact:
Post by Denniss »
A new dangerous Sobig Virus is on it's way through the net !
It's called Sobig-E and uses the usual IE/Outlook way to spread out
http://www.trendmicro.com/vinfo/virusen ... RM_SOBIG.E
http://securityresponse.symantec.com/av ... .tool.html
Deathsythe
Contact:
Post by Deathsythe »
Thanks for the very useful info Denniss. :D
CPU = Intel 3.06ghz
MOTHERBOARD = MSI 875P NEO LSR
RAM = Corsair 1024mb PC2700 XMS
OS = Win XP Sp2
POWER SUPPLY = Antec true power 480w
VIDEO CARD = PNY GF 6600 256MB
CASE =Antec PLUSVIEW 1000AMG
DVD = Lite on 16x
CDRW = Lite on 52x-24x-52x
Denniss
Contact:
Post by Denniss »
Update :
Links to recently discovered new Virusses added
Denniss
Contact:
Post by Denniss »
Some new links and a little redesign
kevinloh
Newer virus
Post by kevinloh »
What do you think about the MSBLAST/LuvSan Virus Worm? It affects WinXP and Win2000. How does it spread?
GIGABYTE GA-X79-UD3
Intel 3930K 3.20Ghz O/C to 4.0GHz
PHANTEKS PH-TC14PE CPU Cooler
16GB CORSAIR DDR3-2133 LP
SAMSUNG 830 256GB SSD SATA3
12TB HDD Drives
EVGA Nvidia 2GB GTX680 Superclocked Signature 2
CORSAIR AX1200W PSU
Sharkoon T28 Green Edition Case
DELL 22 Widescreen LCD Monitor E228WFP
Post Reply
