It is currently Wed Jun 03, 2020 5:53 am
PostPosted: Thu May 08, 2003 7:01 pm
MoBoCop : 22150
- 486 board
- AT POWER
- standard 486 socket with 169 pins (non-ZIF)
- there is UMC CPU installed
- UMC chipset
- 2xSIMM 72 pin
- DIN keyboard
- 6xISA 16 bit
- AMIBIOS
- no keyboard BIOS
- 4+1 cache sockets
- no cache chips installed
- standard 3.6 V Ni-Cd battery (3/V60R)
Data:
"MB459 V1.1" printed sign onboard
"LITE ON 2OVO" 'factory made' on the soldering side (0 or O?)
"PTA-5B 021440" on the label at ISA slot (type and s/n?)
"UMC UM8498F" on bigger chip
"UMC UM8496F" on smaller chip
"AMIBIOS 486DX ISA BIOS '93 AC2001497" on the top label &
"10-04-94" on the bottom label on the BIOS EPROM (there are two overlapping label on it!)
"UMC GREEN CPU U5SX 486-40 UMC'93 Microsoft windows compatible" on the CPU
When I unsocketted the CPU I see this on the rear side of it (on the golded plate capping the CPU):
"NOT FOR U.S. SALE"
Board is OK!
This returns BIOS (it is win-bios!):
At the top:
AMIBIOS (C)1994
At the bottom:
40-P301-001815-00101111-072594-UMC498-H
When Insert is pressed during boot-up:
000-0-0000-00-00-0000-00-00-000
000-0-0000-00-00-0000-00-00-00-0
On the HW table screen:
AMIBIOS Date : 07/25/94
Manufaturer is probably Powertech.
MoBoCop : 22151
- 486 board
- AT POWER
- 486 overdrive socket with 238 pins (non-ZIF)
- option for 486 PQFP CPU
- there is Intel CPU installed
- UNIchip chipset
- 8xSIMM 30 pin
- DIN keyboard
- 4xISA 16 bit
- 3xVLB 32 bit
- AMIBIOS
- keyboard BIOS
- 8+1 cache sockets
- 9 cache chips installed
Data:
"UNICHIP 486 WB" & "4407 REV 1.1" printed sign onboard
"03'93 TREND MICRO DEVICES INC 0394841" on the label at ISA slot (date, manuf. and s/n?)
"UNIchip U4800 -VLX" on bigger chip
"HMC HM82C206" on smaller chip
"AMIBIOS 486DX ISA BIOS '93 AB1163918" on the BIOS label
There is Intel i486SX-25 socketed in
Cache is W24257AK-20 with AE88128AK-15 TAG
Board or/and CPU are maybe bad!
Manufacturer is probably UNIchip (?).
THANK YOU FOR ANY HELP
I also need info on some CPU's. Do anybody know how to set up mobos for IBM or ST CPUs? I apreciate any help...[/img]
PostPosted: Thu May 08, 2003 7:09 pm
Board 1 is a Powertech MB459, no online info yet
Board 2 is a DataExpert 4407, no online info yet.
PostPosted: Thu May 08, 2003 8:58 pm
Hmmm.... :?:
What does it mean? Is there any chance to get manuals for this MoBos???
PostPosted: Fri May 09, 2003 1:52 am
It means it is not easy to find. You need to be lucky enough for someone to have a paper copy of the manual and reading this stuff...
PostPosted: Fri May 09, 2003 7:27 pm
8)
I have the time.... I'll wait....
Huh!
There is something about the second mobo:
http://th99.pley.org/m/U-Z/31875.htm
This looks like it... but there are more jumpers on my board.
This is my board image - looks pretty good. But damn no more info:
http://home.att.ne.jp/alpha/pcboard/0151NN.jpg
It belongs to this page:
http://home.att.ne.jp/alpha/pcboard/486g.htm (the most bottom image)
(info is corect: UNI486WB4407REV1.1)
...any suggestions?
Thanx for anything...
George
PostPosted: Fri May 09, 2003 7:53 pm
Info from TH99 isn't always complete, you are lucky as you are to find anything in the first place. DataExpert is no more and a manual for this board was never published online anywhere.
Do you think you hve enough info to setup the processor and the cache memory? The other jumpers not mentioned are usually not that critical.
PostPosted: Fri May 09, 2003 9:36 pm
Donno... :cry:
I'll take all my luck and fu*k it up with trying this mobo with informations I have now. 8)
OK tomorrow I'll try it. Now it is 3 o'clock here on this ticking thing...
I've to sleep...
Thanx and CYA tomorrow (today)...
Eeeaaah .-O
George Blackhead
PostPosted: Sun May 11, 2003 5:33 pm
:cry: :cry: :cry:
Things go bad...
I tryied the mobo with manual I had downloaded from TH99... but no luck!
I'll wait if someone has it... :cry:
Thanx and CYA
George Blackhead
PostPosted: Thu Oct 09, 2003 1:20 pm
2blackhead - have you revealed anything about the first discussed board ???? I'm using it with UMC U5SX 33 in my Linux box - but /proc/cpuinfo claims the CPU has ony 12.9 bogoMIPS - could it be due to lack of cache chips ??? Any idea what SRAM chips should I buy ?
THX
Users browsing this forum: Google [Bot] and 0 guests
