It is currently Sat Feb 16, 2019 6:09 pm
Post new topic Reply to topic  [ 27 posts ]  Go to page 1, 2, 3  Next
PostPosted: Tue Jun 25, 2002 11:56 am
May not be standard beep codes but are most common. Depending on the BIOS manufacturer, the keyboard controller failure could be three, four, five, or six beeps. Always consult your motherboard documentation
and BIOS manufacturer.
Hope this might help :wink:
GoodLuck!!!
:idea: AMI BIOS
Number of beeps Problem description Troubleshooting recommendation
1
Refresh error Reseat memory or replace with known good chips.
2
Parity error Reseat memory or replace with known good chips.
3
Base 64K memory failure Reseat memory or replace with known good chips.
4
Timer not operational Repair/replace motherboard.
5
Processor error Repair/replace motherboard.
6
8042__gate A20 failure Reseat keyboard controller chip, replace keyboard controller chip, check for a keyboard fuse, or try a different keyboard.
7
Processor exception interrupt error Repair/replace motherboard.
8
Display memory read/write failure Replace video card or video card memory.
9
ROM checksum error/Faulty BIOS chips Replace chips or motherboard.
10
CMOS shutdown register read/write error Repair/replace motherboard.
11
Cache memory bad
:idea: Award BIOS
http://www.phoenix.com/pcuser/awardbios ... codes.html
Number of beeps
1 long & 2 short
Video error Check the video card.
Any other beeps
RAM problem Reseat the RAM or replace with known good chips.
:idea: PhoenixBIOS
Unfortunately, PhoenixBIOS beep codes are significantly more complicated than other BIOS manufacturers. Instead of a single beep code set, PhoenixBIOS codes consist of a series of beep code sets separated by a short pause. Older Phoenix BIOS Plus and PhoenixBIOS 1.x systems used a series of three sets, while the new PhoenixBIOS 4.x systems use a series of four sets. The codes listed below are only some of the more than 100 codes for the newer PhoenixBIOS 4.x. For a complete list of Phoenix BIOS POST task routines and beep codes, please visit their Web site or review your motherboard's documentation.
Number of beeps
POST routine description/problem Troubleshooting recommendation
1
One short beep before boot Normal operation
1-1-1-3
Verify real mode A problem exists with the CPU and/or motherboard. Check and replace if necessary.
1-1-2-1
Get CPU type A problem exists with the CPU and/or motherboard. Check and replace if necessary.
1-1-2-3
Initialize system hardware A problem exists with the motherboard. Check and replace if necessary.
1-1-3-1
Initialize chipset with initial POST values A problem exists with the motherboard. Check and replace if necessary.
1-1-3-2
Set IN POST flag A problem exists with the motherboard. Check and replace if necessary.
1-1-3-3
Initialize CPU registers A problem exists with the CPU and/or motherboard. Check and replace if necessary.
1-1-4-3
Initialize I/O component A problem exists with the I/O port hardware or a device connected to an I/O port. It could also be an expansion device in the PC or the motherboard.
1-2-2-1
Initialize keyboard controller An error has occurred with the keyboard or keyboard controller. Try a new keyboard or replace the keyboard controller on the motherboard.
1-2-2-3
BIOS ROM checksum Replace either the BIOS ROM chip or the motherboard.
1-2-3-3
8237 DMA controller initialization Check the motherboard and any expansion cards that use DMA.
1-3-1-1
Test DRAM refresh Check the first bank of memory and the motherboard.
1-3-1-3
Test 8742 keyboard controller An error has occurred with the keyboard or keyboard controller. Try a new keyboard or replace the keyboard controller on the motherboard.
1-3-4-1
RAM failure on line xxxx Check the first bank of memory and the motherboard.
1-3-4-3
RAM failure on data bits xxxx of low byte memory bus Check the first bank of memory and the motherboard.
2-1-3-1
Check video configuration against CMOS Check the video card or video card memory.
2-1-3-2
Initialize PCI bus and devices A problem exists with the I/O port hardware or a device connected to an I/O port. It could also be an expansion device in the PC or the motherboard.
2-2-1-3
Test keyboard An error has occurred with the keyboard or keyboard controller. Try a new keyboard or replace the keyboard controller on the motherboard.
2-2-3-1
Test for unexpected interrupts Check for a faulty motherboard or expansion card.
3-1-2-1
Detect and install external parallel ports A problem exists with the I/O port hardware or a device connected to an I/O port. It could also be an expansion device in the PC or the motherboard.
3-1-4-1
Initialize floppy controller Check your hard drive(s), floppy drive(s), and motherboard.
3-2-1-1
Initialize hard-disk controllers Check your hard drive(s), floppy drive(s), and motherboard.
3-2-1-2
Initialize local-bus hard-disk controllers Check your hard drive(s), floppy drive(s), and motherboard.
3-3-1-1
Set time of day Check the motherboard's real-time clock (RTC).
4-2-4-3
Keyboard controller failure An error has occurred with the keyboard or keyboard controller. Try a new keyboard or replace the keyboard controller on the motherboard.
:idea: Dell BIOS
Because Dell uses motherboards and BIOSs from several manufacturers, their computers use a variety of beep codes. Instead of listing each model's beep codes, links are provided to the support pages of several popular Dell desktops.
Model System codes and messages link
Dimension 900 http://docs.us.dell.com/docs/systems/dc ... demess.htm
Dimension 2100 http://docs.us.dell.com/docs/systems/di ... demess.htm
Dimension 4100 http://docs.us.dell.com/docs/systems/dzuul/codemess.htm
Dimension 4200 http://docs.us.dell.com/docs/systems/dim4200/codes.htm
Dimension 4300 http://docs.us.dell.com/docs/systems/dim4300/codes.htm
Dimension 4300S http://docs.us.dell.com/docs/systems/dim4300s/codes.htm
Dimension 4400 http://docs.us.dell.com/docs/systems/dim4400/codes.htm
Dimension 8100 http://docs.us.dell.com/docs/systems/ds ... demess.htm
Dimension 8200 http://docs.us.dell.com/docs/systems/dim8200/codes.htm
Dimension C http://docs.us.dell.com/docs/systems/dc ... demess.htm
Dimension L http://docs.us.dell.com/docs/systems/dmum/codemess.htm
Dimension Lxxxc http://docs.us.dell.com/docs/systems/dcol/codemess.htm
Dimension P133a, P166a, M166a, M200a, and M233a http://docs.us.dell.com/docs/systems/dhanplus/post.htm
Dimension XPS Txxx and Txxxr http://docs.us.dell.com/docs/systems/dkub/codemess.htm
Dimension Vxxx and Vxxxc http://docs.us.dell.com/docs/systems/dwill/post.htm
Dimension XPS B Series http://docs.us.dell.com/docs/systems/dmag/codemess.htm
Dimension XPS Dxxx http://docs.us.dell.com/docs/systems/dalex/post.htm
Dimension XPS H233 and XPS H266 http://docs.us.dell.com/docs/systems/dcor/post.htm
Dimension XPS P60 FS http://docs.us.dell.com/docs/dta/xpsp60f/00000015.htm
Dimension XPS P60 MDT http://docs.us.dell.com/docs/dta/xpsp60m/00000014.htm
Dimension XPS 50/66 FS http://docs.us.dell.com/docs/dta/xps_f/00000021.htm
Dimension XPS 50/66 MDT (V4xxV) http://docs.us.dell.com/docs/dta/xps_m/00000025.htm
Dimension XPS Rxxx http://docs.us.dell.com/docs/systems/dkhan/post.htm
OmniPlex 5xx/ME http://docs.us.dell.com/docs/dta/omni5xx/00000051.htm
OptiPlex G1 http://docs.us.dell.com/docs/systems/ddur/beep.htm
OptiPlex GC http://docs.us.dell.com/docs/systems/op ... ssages.htm
OptiPlex Gn and Gn+ http://docs.us.dell.com/docs/systems/dthred/beep.htm
OptiPlex GX1 http://docs.us.dell.com/docs/systems/ban_gx1/beep.htm
OptiPlex GX1 Small-Form-Factor http://docs.us.dell.com/docs/systems/ba ... ssages.htm
OptiPlex GX1p http://docs.us.dell.com/docs/systems/d_gx1p/beep.htm
OptiPlex GXi http://docs.us.dell.com/docs/systems/dzer/beep.htm
OptiPlex GX100,GX110,GX200,GX300 http://support.dell.com/us/en/kb/docume ... DN=1040268
OptiPlex GX110 http://docs.us.dell.com/docs/systems/op ... ssages.htm
OptiPlex GX115 http://docs.us.dell.com/docs/systems/op ... ssages.htm
OptiPlex GXa http://docs.us.dell.com/docs/systems/dfuj/beep.htm
OptiPlex GXpro http://docs.us.dell.com/docs/systems/ds ... stbeep.htm
OptiPlex N http://docs.us.dell.com/docs/systems/dkill/beep.htm
OptiPlex NX http://docs.us.dell.com/docs/systems/dfujnx/beep.htm
OptiPlex NX1 http://docs.us.dell.com/docs/systems/ban_nx1/beep.htm
OptiPlex XMT575/590/5100/5120/5133 http://docs.us.dell.com/docs/dta/586xmt/00000038.htm
Precision WorkStation 210 http://docs.us.dell.com/docs/systems/daftshk/beep.htm
Precision WorkStation 340 http://docs.us.dell.com/docs/systems/ws ... /codes.htm
Precision WorkStation 400 http://docs.us.dell.com/docs/systems/dtor/beep.htm
Precision WorkStation 410 http://docs.us.dell.com/docs/systems/deqkmt/beep.htm
Precision WorkStation 420 http://docs.us.dell.com/docs/systems/ws ... ssages.htm
Precision WorkStation 530 http://docs.us.dell.com/docs/systems/ws ... 2codes.htm
Precision WorkStation 610 Mini Tower http://docs.us.dell.com/docs/systems/dvol/beep.htm
Precision WorkStation 620 http://docs.us.dell.com/docs/systems/ws ... ssages.htm
Precision WorkStation 730 http://docs.us.dell.com/docs/systems/ws ... ssages.htm
Image Image
PostPosted: Tue Jun 25, 2002 8:40 pm
Cool info. This one gets printed for my reference file. Thanks.
PostPosted: Tue Jun 25, 2002 10:14 pm
YW Wyrm. :lol:
Image Image
PostPosted: Tue Jun 25, 2002 10:33 pm
i think this needs to be moved to a sticky thread that always stays up top for refrence. :wink: so sombody tell mobocop to stop being lazy and get one of his minions[moderators] in here to do it. :P :lol: :P :lol:
PostPosted: Tue Jun 25, 2002 10:42 pm
Well done TheEvilOnE. I agree Datektrader this should be "sticky" for reference puposes.
Toby
Compaq-Fu Master
PostPosted: Tue Jun 25, 2002 10:45 pm
I too agree it should be a sticky.
"Ew, it's all sticky"
Goddam mad dog!
PostPosted: Wed Jun 26, 2002 12:29 am
Sticky meaning those with "goo" on top of the forum??? That'll work. It is a good reference. I wonder what's that sticky goo made of :roll:
Image Image
PostPosted: Wed Jun 26, 2002 1:32 am
I think they pull :wink: it out of a dumpster behind a sperm bank and and swirl some vegamite in it for color :twisted:
1. If you don't know ask-
2. If you do know tell -
3. If you think you know refer to 1.
PostPosted: Wed Jun 26, 2002 9:15 am
Try this:
http://www.bioscentral.com/
"I can't buy that. Only management guys with big salaries like me can afford that...
Guys like me! I'm a guy like me!"
Homer Simpson :)
PostPosted: Tue Jul 30, 2002 7:10 pm
not sure if this info will be useful to anyone but i recently needed the beep codes for PhoenixBIOS A486:
This POST/BEEP code list is applicable only to Phoenix ROM BIOS PLUS or PhoenixBIOS A286/A386/A486 Version 1.xx on an AT-class (80286 or higher) system.
Port
80h Beep
Value Code Error/Test Description
01h none 80286 register test in progress
02h 1-1-3 CMOS write/read test in progress or failure
03h 1-1-4 BIOS ROM checksum in progress or failure
04h 1-2-1 Programmable Interval Timer test in progress or failure
05h 1-2-2 DMA initialization in progress or failure
06h 1-2-3 DMA page register write/read test in progress or fail
08h 1-3-1 RAM refresh verification in progress or failure
09h none 1st 64K RAM test in progress
0Ah 1-3-3 1st 64K RAM chip or data line failure - multi-bit
0Bh 1-3-4 1st 64K RAM odd/even logic failure
0Ch 1-4-1 1st 64K RAM address line failure
0Dh 1-4-2 1st 64K RAM parity test in progress or failure
10h 2-1-1 1st 64K RAM chip or data line failure - bit 0
11h 2-1-2 1st 64K RAM chip or data line failure - bit 1
12h 2-1-3 1st 64K RAM chip or data line failure - bit 2
13h 2-1-4 1st 64K RAM chip or data line failure - bit 3
14h 2-2-1 1st 64K RAM chip or data line failure - bit 4
15h 2-2-2 1st 64K RAM chip or data line failure - bit 5
16h 2-2-3 1st 64K RAM chip or data line failure - bit 6
17h 2-2-4 1st 64K RAM chip or data line failure - bit 7
18h 2-3-1 1st 64K RAM chip or data line failure - bit 8
19h 2-3-2 1st 64K RAM chip or data line failure - bit 9
1Ah 2-3-3 1st 64K RAM chip or data line failure - bit A
1Bh 2-3-4 1st 64K RAM chip or data line failure - bit B
1Ch 2-4-1 1st 64K RAM chip or data line failure - bit C
1Dh 2-4-2 1st 64K RAM chip or data line failure - bit D
1Eh 2-4-3 1st 64K RAM chip or data line failure - bit E
1Fh 2-4-4 1st 64K RAM chip or data line failure - bit F
20h 3-1-1 master DMA register test in progress or failure
21h 3-1-2 slave DMA register test in progress or failure
22h 3-1-3 master interrupt mask register test in progress or fail
23h 3-1-4 slave interrupt mask register test in progress or fail
25h none interrupt vector loading in progress
27h 3-2-4 keyboard controller test in progress or failure
28h none CMOS power-fail and checksum checks in progress
29h none CMOS config info validation in progress
2Bh 3-3-4 screen memory test in progress or failure
2Ch 3-4-1 screen initialization in progress or failure
2Dh 3-4-2 screen retrace tests in progress or failure
2Eh none search for video ROM in progress
30h none screen believed operable:
30h none screen believed running w/ video ROM
31h none monochromatic screen believed operable
32h none 40-column color screen believed operable
33h none 80-column color screen believed operable
34h 4-2-1 timer tick interrupt test in progress or failure
35h 4-2-2 shutdown test in progress or failure
36h 4-2-3 gate A20 failure
37h 4-2-4 unexpected interrupt in protected mode
38h 4-3-1 RAM test in progress or failure above address 0FFFFh
3Ah 4-3-3 Interval timer channel 2 test in progress or failure
3Bh 4-3-4 Time-Of-Day clock test in progress or failure
3Ch 4-4-1 Serial port test in progress or failure
3Dh 4-4-2 Parallel port test in progress or failure
3Eh 4-4-3 Math Coprocessor test in progress or failure
Error codes in the 50h range or beyond are chip set or custom platform specific, and will vary from system to system. Contact your system manufacturer for details.
________________
[b]
Quote:
Even old dogs(like me) can learn new tricks
b]
