What is your highest overclock?
Postby ghostrider03 » Sat Sep 10, 2005 7:59 am
I have recently change my mobot & chip. It started at 2.93GHz and now it at 3.27GHz. All I did was change the FSB setting from 133MHz to 147MHz, and at this setting it is stable & at low temp(41c to 45c).
When I take it to a higher FSB setting it it becomes very unstable. I think my video card can't work at that setting, but I'm in the process of upgrading it. I am please with it since it's the frist time I have oced one. :)
MOBOT:Soyo SY-P4VTE
CPU:Intel Celeron 533MHz 2.93GHz
RAM:Ultra 512MB PC3200 400MHz DDR SDram
COOLING:Ultra Fire Pentium 4
BIOS SETTING:FSB 133MHz
Well this just the begianning of what could come with this system,will do more after the upgrade process is completed. :wink:
Ghostrider03
ghostrider03
Postby aussiejunior » Mon Oct 31, 2005 5:41 pm
I hope you guys include videocards in this section. I got my 256mg geforce 5700ve to run at the 5700 ultra settings without glitching :) ithough that was kinda kool
core i7 920@4.0ghz
asrock x58 extreme 3
Creative x-fi xtreme gamer
aussiejunior
Postby aussiejunior » Mon Nov 21, 2005 3:17 pm
amd semperon 2600 (socket 754)
gigabyte ga K8n I think not 100 percent sure
stock cooling
running at 1920mhz (faster then the sempron 3100 :) )
values. fsb 240
multi 8
stock voltage
temp hasnt run higher th3n 40c at a room temp of 30c
core i7 920@4.0ghz
aussiejunior
Postby sbrehm72255 » Sat Mar 04, 2006 7:15 am
This is nothing all that great, but it's the best I can get.
In this pic I was messing with OC'd ram timings and this is what I ended up with 1:1.
sbrehm72255
Postby aussiejunior » Tue Mar 28, 2006 7:19 am
got a new one for u guys.
amd 3200 64bit 939.
asus a8v motherboard
768 ddr400 legend ram in single chanel
500w psu.
geforce 5700ve
Runnin at 1.7v the cpu was easyily oc'd to 2600mhz
and the vid card i was able to get the core clock speed to 500mhz
and the mem to 492 mhz...
everythng ran beautifly cept for the cpu which was overheating alil
setting on the cpu was 260*10 coz thats as high as the multi goes
core i7 920@4.0ghz
aussiejunior
Postby zachig » Thu Mar 30, 2006 10:09 am
I've reached 2310Mhz from my stock Barton 2500+ (1833Mhz). I think I could get more but my Epox 8RDA3+ rev 1.1 was limiting me.
I currently own X2 3800+ but I havn't overclocked it (...yet :wink: ).
zachig
Postby ajrox » Sun May 14, 2006 6:15 am
opty 165
stock 1.8ghz @ 200fsb
OCed 2.475ghz @ 275fsb
everything on air, no voltage adjustment of any kind. just upped the FSB and let her rip!
X2 4800 speeds and benches as such.
i recommend an opteron to all you guys. you'll love it!
AJ :o
EVGA 790i tri SLI
intel core2 quad 9550
6gb G.SKILL DDR3 16000
3X EVGA 8800gts video cards
water cooled fo sho
the rest when i get paid
ajrox
Postby aussiejunior » Fri May 26, 2006 6:49 am
ok got some new memory and tried a max oc again with my 3200 939.
Can get her to let rip now at 2.8 ghz...
Setting of
v.core 1.7
280*10
ram oc'd nicely to ddr 470mhz (235 ram speed) :) not bad considering it's only a generic deriative of hyunix.
Can't get me new vid card to oc much... thats coz it's a xfx and theyre allready oc'd :)
Posted a score of 33 sec in super pi and i think it was 283 in 3d mark o6... not too bad for an agp 8x xfx 6200
aussiejunior
Postby somedude » Fri Jun 23, 2006 1:54 pm
Mobo: Asus A7V880
Chip: XP 1800+ AXDA1800DLT3C
RAM: DDR400 2@512M Samsung
Cooler: Zalman CNPS7000B-ALCU
BIOS: 11.5x (default) 209MHz FSB 1.65V Core
Result: a whopping 2.4GHz!
Temps: 42 idle, 48 full blast (as reported by speedfan)
AGP is slighly o/c'd (69.6MHz) as well as PCI (34.8MHz)
So far so good. Running stable for three days now.
I also tried a Sempron 462 2200+ SDA2200DUT3D but it became unstable past 1.75GHz, in spite of the default 166MHz bus.
"I can't buy that. Only management guys with big salaries like me can afford that...
Guys like me! I'm a guy like me!"
Homer Simpson :)
somedude
Postby iamwhoiamtoday » Mon Aug 21, 2006 3:05 pm
Intel 805 (2.66ghz) at 3.4ghz on stock cooling and stock voltage
iamwhoiamtoday
PreviousNext
