Need help identifying the MB in my IBM Aptiva 2158-240
bomber007
Post by bomber007 »
I'm hoping to upgrade the CPU in my Aptiva 2158-240 from the OEM installed K6/2-350 but can't find out what, if any processor is supported. I have some info from running BIOS Wizard... BIOS Manufacturer = ACER OEM. BIOS ID is IBM95000-M15-991005-R02-D0 EN. Chipset = ALi M1451 rev 4. Please help!
Contact:
Post by evasive »
bomber007
Post by bomber007 »
Thanks! Any knowledge of the fastest CPU this board can handle? The spec sheet indicates 400MHz and "higher".
Contact:
Post by evasive »
I fear you have to rely on either Acer tech support or IBM tech support on this one. I suggest you send both of them an email.
Aussie
Post by Aussie »
The board has settings for 100MHz FSB and multipliers up to 5.5x as well as Vcore settings for 2.2 volts so any K6-2 up to 550MHz should work in the board.
Aussie
Contact:
Post by evasive »
Bios support and all? IBM bioses are known to refuse startup with a processor inside that is not listed in their CPU code table...
Aussie
Post by Aussie »
The K6-2 500MHz is listed in their service parts list that you linked to. :lol:
http://www.pc.ibm.com/qtechinfo/DETR-3YVPS9.html
Aussie
Contact:
Post by evasive »
don't see 550 there...
Aussie
Post by Aussie »
Splitting hairs now aren't we?
The board has jumpers for 5.5x and we Know it will run a 500 so I don't see why it wouldn't run an identical processor that is 50MHz faster.
The bios obviously has support for the K6-2 "family" of processors so I suspect the worst that could happen is that the processor speed may be incorrectly reported IF the 550 wasn't listed in the bios CPU table.
Personally I think that a K6-2 550 is a pretty safe bet in the V72MA.
Aussie
bomber007
Post by bomber007 »
Thanks for the insight(s). The only way to find out for sure is to take the plunge; which I am doing. Any thoughts on the K6/2 - 533 cpu. I posted an inquiry with AMD Tech Support but have not heard back yet. Worth a try with the V72MA :?: ?
Post Reply
