Can you help me to solve this please?
Postby Adrian » Fri Oct 20, 2017 10:21 pm
My pc show me cpuid:0001067A Patch ID:0A07 and doesent start.
Adrian
Re: Can you help me to solve this please?
Postby Karlsweldt » Sat Oct 21, 2017 6:25 am
Moved your post to a more appropriate sector.
Please post more details about your system.. motherboard model, CPU model, type of memory, PSU wattage and other features such as video card. This helps in providing a better diagnosis.
If a CPU is not compatible to a motherboard design, usually will not show life signs. At the worst, can cause a fatal short.
Memory too must be compatible to the motherboard and system speeds.
Postby Adrian » Sat Oct 21, 2017 10:42 am
Thank you for your answer but i realised the cpu q9650 is not compatible with my motherboard GA-945GCMX-S2.
Adrian
Return to Tech Support
Users browsing this forum: YandexBot [Bot] and 2 guests
