app for file transfer Android to Imac
Postby poundu1 » Tue Sep 19, 2017 1:31 pm
New LG phone to OSX Sierra.
Trying to get the pictures from phone to Imac with USB cable.
Image capture does not recognize device when USB is plugged in to Android phone.
Image Capture automatically detects when I plug Iphone in.
Any suggestions?
Thanks
crispr edit
poundu1
Re: app for file transfer Android to Imac
Postby Karlsweldt » Wed Sep 20, 2017 7:34 am
May be a difference with USB port classes. The older class hubs are not forward compatible to newer devices, but newer devices are supposed to be backward compatible. Or could be incompatible format of files.
Did find this..
https://www.androidphonesoft.com/resour ... phone.html
Postby poundu1 » Wed Sep 20, 2017 8:05 am
Developer option - debug USB
Worked perfectly!
Thank you
crispr edit
poundu1
Return to Tech Support
Users browsing this forum: trendictionbot [Bot] and 3 guests
