Canon i560 injet drivers off MS's site won't install - Win7
Goto page 1, 2  Next
videobruce
PostPosted: Sat Aug 31, 2013 6:07 am    Post subject: Canon i560 injet drivers off MS's site won't install - Win7 Reply with quote
I finally managed to d/l the x64 driver for this printer directly from MS's update site as opposed to doing it through update driver since I want a copy of the driver so I can load off line like I do with all other drivers for the past 13 years.
I finally managed to figure out how to get the driver without using the "update driver" through Device Manager that automatically d/l's the driver, installs it but with no copy saved for backup. You have to repeat the process if you re-install the O/S which is stupid and unnecessary.
That is after you change the setting under "Device Installation Settings" to "Yes do this automatically" since it won't work if you leave it at the default setting.
The two packages I have are x86 & x64 for this i560. Using the .inf file, both return the same message that is isn't the correct driver. There is no .exe so I can run it by itself.
Canon has some file that is suppose to work, but with no details just how to use it. A fix for the problem. I tried that, but that has absolutely no effect.
Any ideas here, I have never needed to do all of this for any device .
Copyright protection & Intellectual property my ass. All the studios want is more money & control. Enough is enough!
Toby B.
PostPosted: Sat Aug 31, 2013 7:22 am    Post subject: Reply with quote
Microsoft can't even get an operating system correct, let alone try and provide driver support for devices they don't make..
My recommendation would be to contact cannon, and make a request for a new driver..
We Help You. You Can Help Us!
Link to us from your pages
View user's profile Send private message Send e-mail Visit poster's website
PostPosted: Sat Aug 31, 2013 1:30 pm    Post subject: Reply with quote
send the .inf files to elhvb@outlook.com and I'll try and see if I can make something decent out of them. There's a good chance I will ask for additional files (that are listed inside the .inf). If all goes well I should be able to package them into an .msi for you.
videobruce
PostPosted: Sun Sep 01, 2013 7:22 am    Post subject: Reply with quote
I would be the last to argue that.
What Canon USA has is here;
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/i_series/i560_series?#DriversAndSoftware
What the UK site has is here;
http://www.canon.co.uk/Support/Consumer_Products/products/printers/InkJet/i_series/Bubble_Jet_i560.aspx?DLtcmuri=tcm:14-729895&page=1&type=download
BOTH only have this "add on module", NOT the base drivers which is what I need.
After a very lengthly search I came across this post elsewhere which answered why the update drivers didn't work initially. But, that isn't solving the problem!;
Quote:
AdamCUK replied on August 1, 2011
The actual problem is that Windows is set by default not to download drivers automatically from Windows Update,
despite the fact that this is the "recommended" setting. If you set Windows to download drivers automatically
then the printer installs automatically.
Canon does not provide this driver on their website. It is provided by MICROSOFT via Windows Update.
Click the Windows button and choose Control Panel.
Select "System" then "System and Security".
Choose "Advanced System Settings".
Choose the "Hardware" tab and click on the "Device Installation Settings" button.
Choose "Yes, do this automatically (recommended)", then click on "Save changes".
Now add the printer again and it should work.
Managing to find Microsoft's Update Catalog site for driver downloads (which I have never used or even heard of since I never had a need for it in 13 years) I obtained both versions for Win7 (x86 & x64 just in case). Since neither have a .exe file they have to get installed via a .inf file which leads to the problem, both get rejected which puts me back to square one.
In case anyone doesn't see the problem here, very simply; what happens when MS removes those drivers (via the auto update process)? Throw the printer out?? THERE IS NO WAY TO SAVE THEM!
The two files I did manage to get that won't install are;
"IA64-all-4242_cb2300bd637e6269cfc1ac59ab526914b72bb832.cab"
"X86-all-200000019_4f20dba9f69de9656cf1d53cc95f930625c8f1d7.cab"
PostPosted: Sun Sep 01, 2013 10:22 am    Post subject: Reply with quote
Have you tried this site? A drop-down menu has many OS versions listed.
http://www.usa.canon.com/cusa/windows_7/printers/i_series/i560_series?selectedName=DriversAndSoftware
You may have to uninstall the drivers after removing the printer. Having a 'duplicate' printer of the same model can confuse the OS.
videobruce
PostPosted: Sun Sep 01, 2013 12:54 pm    Post subject: Reply with quote
Yes, it was one of the links I provided. The only thing that is there is that mostly useless add on.
PostPosted: Mon Sep 02, 2013 12:25 am    Post subject: Reply with quote
ok, then send the cab files to me so I can unpack/analyze them and see if I can build an installer for you. It's what I do for a living cool
videobruce
PostPosted: Mon Sep 02, 2013 8:21 am    Post subject: Reply with quote
Ok, sent. I was going to but got distracted.
bdub
PostPosted: Tue Sep 03, 2013 6:02 am    Post subject: Reply with quote
does installing in winxp compatibility mode ever work for printer drivers. i thought it worked sometimes?
my main rig...
asrock 970 extreme3
AMD athlonII X3 440
zalman cpns5x performa hs/fan
antec neo he 650r
kingston hyperx 3k ssd 120GB
seagate 500GB HDD 32M cache
seagate 750GB HDD 32M cache
hitachi 1TB HDD 32M cache
lg wh14ns40 bd burner
PostPosted: Tue Sep 03, 2013 11:08 am    Post subject: Reply with quote
Installing a printer on most computers today is not as simple as years ago!
Some models require first connecting the printer, then installing the software from the driver disk. Some first require the software be installed, then the printer! And many providers request that you bypass the OS search for the drivers, and install them manually!
Some newer models have a ROM chipset in the machine, which has all the info needed to make it work properly. Or maybe not!
An OS that is 64-bit based will still default to 32-bit status with devices and drivers. But not backward to 16-bit unless in command-prompt mode.. which is being phased out with all the other "legacy" features.
Try removing all print devices from the system.. including any "remote" devices. Then uninstall the drivers. You may have to go to the folder for the program, and look for a file likely named "Unwise.exe" or similar to remove any remnants of the driver.
Then reboot, set a default printer as "text only". Then install the printer of choice as recommended by the provider. It then should become the default printer.
Goto page 1, 2  Next
Page 1 of 2
