GEORGIAN Black Belt
Posted: Mon Aug 26, 2013 5:23 pm Post subject: NO SOUND problem on M2N68-LA |
Hi guys.
I have Compaq Presario CQ5300F PC with ASUS M2N68-LA board (AM2 board) in with Windows 7 Premium. So i decided to re install OS by W 7 PRO.
Everything went OK but when i tested for sound find just DUMMY speakers.
Changed speakers by another ones, tested by Earphones-NOTHING.
Re installed sound driver by original Compaq one-NOTHING. Then installed drivers from ASUS site but i have "0" results.
I see sound waves are moving while playing something.
Device Manager shows Sound Card drivers W/O problems.
On PC is installed HP advisory for support and test went OK, didn't find any problems with sound.
Installed Driver Magician for additional drivers, installed all MB and chipset drivers also, still nothing.
Any recommendations? _________________
Toby B. Lead Mobo-fu Master
Posted: Mon Aug 26, 2013 5:34 pm Post subject: |
You won't find anything on the Asus site, since this board is an OEM board not a retail board..
So all you did is install a new version of the OS? All the speaker wires remained connected? by the sounds of it the speakers are hooked up wrong. _________________ We Help You. You Can Help Us!
Link to us from your pages |
Posted: Mon Aug 26, 2013 5:40 pm Post subject: |
There are several incarnations of that board, that have different specs based off of BIOS, and features (like RAM slots), so the exact details might differ from your board...
but the manual that I have available, at least the one I know of off hand:
http://ctechinfo.net/documentation/manuals/narra3_manual.pdf
And although the manual says Asus, the board is produced by Pegatron which at one point was the OEM leg of Asus, but has since been split off to its own company.. _________________ We Help You. You Can Help Us!
GEORGIAN Black Belt
Posted: Mon Aug 26, 2013 5:45 pm Post subject: |
Thanks for reply.
How speakers could be hooked wrongly if it has just 3 ports and i tried all of them, Earphones also front-back.
Do you think board is dead and that's why? _________________
Posted: Mon Aug 26, 2013 5:57 pm Post subject: |
| GEORGIAN wrote: | Thanks for reply.
Do you think board is dead and that's why? |
Very carefully, have done it myself. If not paying close attention.. At least that's what it sounds like at the monent..
You said you installed Win7 Pro?? Did you format the hard drive and install the new OS? Might be worth while to do a restore to the original OS, see if the sound works again, then "Upgrade" versus full install..
If the OS/Device Manager is showing no problems.. Then I would have to assume there is a connection problem or the speakers are fubar'ed..
Drawing a blank on what sound chip is offered on the board, so it would be difficult at this time to track down a driver for it.. _________________ We Help You. You Can Help Us!
Posted: Mon Aug 26, 2013 5:59 pm Post subject: |
And another thing I just thought of... IIRC that board is subject to bad caps, that may or may not be the culprit as well..
www.badcaps.net _________________ We Help You. You Can Help Us!
GEORGIAN Black Belt
Posted: Mon Aug 26, 2013 6:02 pm Post subject: |
I re installed OS by Original Compaq System by image file and no results, also installed new Windows 8 OS but nothing.
Only thing i upgraded was some RAM and PSU.
PSU could cause CAP damage? They look OK, not first time builder.
Do you recommend to remove MOB from case and try like that? _________________
Posted: Mon Aug 26, 2013 6:19 pm Post subject: |
not to my knowledge (on the PSU, causing bad caps.).. But certain brands of PSU's used in Compaq/HP systems have been susceptible to bad caps..
bad caps is really the same as any other faulty mass produced item.. at one point the computer industry was primarily using one cap supplier and there was a really bad string of batches produced..
At this point I am grasping at straws. Been up since 4AM (UTC-5)..
My strength is ID'ing the boards, not so much diagnosing them anymore.. _________________ We Help You. You Can Help Us!
GEORGIAN Black Belt
Posted: Mon Aug 26, 2013 6:26 pm Post subject: |
Thanks man, PSU is NON Compaq one, so i guess if out of case will have negative results only choice will be buy new board for it. _________________
Posted: Mon Aug 26, 2013 6:33 pm Post subject: |
| GEORGIAN wrote: | | Thanks man, PSU is NON Compaq one, so i guess if out of case will have negative results only choice will be buy new board for it. |
No there should be no ill effects from trying it outside the case..
just for curiosity sake, whats the make/model of PSU?? _________________ We Help You. You Can Help Us!
