MOTHERBOARD provides clear graphics & high end sound?
Postby vinerey » Wed Jun 12, 2013 11:30 am
hey guys.. I need help as I am looking around to see what good Motherboard I can have! I will use it more of editing videos, then i will need best choice which will provide good graphics and audio for my videos and it should be working very fast..
any suggestions?
vinerey
Postby evasive » Thu Jun 13, 2013 6:30 am
That also depends on your video card, processor, how much memory you put in, what kind of disk or SSD so... what is your budget for the total system?
Postby vinerey » Thu Jun 13, 2013 12:06 pm
I already decided for an AMD A8-6500 using 8 GB of DDR3.
What i am not yet sure is the graphics card and the motherboard. My last system was using a biostar board and until now i was quite happy. So I am thinking to stick with that, but switch to a newer generation.
What do you think of the A55S3?
As i am in the motherboard forum i was hoping you could give me some insights about what is a good match for that processor and my usage profile. Maybe here are some user experiences already PDT_Armataz_01_01
for graphics i guess some mainstream ATI will do fine. Generally I am thinking to spend no more than 300 dollars for both parts.
vinerey
Postby c327 » Thu Aug 01, 2013 4:50 pm
Wouldn't a motherboard with on board graphics have more draw on the PC's CPU than if the PC had a separate video card ?????
c327
Postby evasive » Thu Aug 01, 2013 10:56 pm
just for the power, not for the processing speed, the graphics is done by a seperate section on the APU.
Postby Mr T » Fri Aug 02, 2013 11:10 am
look for the A75 or A85X AMD chipset, you will get more out of the CPU (or APU) with these.. BIOSTAR are OK as a budget board, but check out ASRock, Gigabyte and some of the lower end ASUS boards will suit your needs...
Return to Recommendations
