jcn Initiate
Posted: Tue May 07, 2013 10:10 am Post subject: Please help with XP reinstall issue. |
Hi, it's a long story why, but my Toshiba laptop required a system reinstall. That was done from the recovery disk provided. It all works ok now but there is one problem.
The computer was bought in 2006; the recovery disk reinstalled a "service pack 2" version. Microsoft no longer supports XP unless it has "service pack 3", right?
So, what do I do? _________________ ASUS P4S8X motherboard.
Intel(R) Pentium(R) 4 CPU 2.53GHz Northwood.
3GB DDR.
Gigabyte R970 PRO Graphics Accelerator.
USB Modem for BB.
Maxtor 80GB hard drive.
52x CD ROM Drive.
Floppy Drive.
Microsoft Windows XP Home Edition.
PSU, 420 W, P4. |
Mr T Enlightened Master
Posted: Tue May 07, 2013 11:09 am Post subject: |
Make sure windows is activated, make sure the time and date is correct, make sure you are online then go to programs and click on windows update. It will take a while so leave it to do it. After SP3 installs, there are in the region of 127 further updates, so be patient. _________________ I have been programming on computers since the ZX81.
Roach412 Black Belt 2nd Degree
Joined: 09 Aug 2004 Posts: 2477 Location: Milwaukee - Wisconsin
Posted: Tue May 07, 2013 11:43 am Post subject: |
you might have to literally google for a location to download SP3 from. that's exactly what i ended up doing when i did a clean install from a non-SP disk. needless to say it took a while. downloaded SP1, installed, downloaded SP2, installed, downloaded SP3, installed...then it would allow me to do the auto updates.
-Roach _________________ Lian Li Lancool First Knight Series PC-K59W
EVGA GTX 560ti FPB
Crucial M4 128gb SATAIII SSD
Corsair Professional Series HX850 PSU |
Hardware Junkie Mobo-fu Master
Joined: 25 Jan 2001 Posts: 19367 Location: 00000h - 0000Fh
Posted: Tue May 07, 2013 1:10 pm Post subject: |
Just get it from here and install it. I do it all the time.
http://www.microsoft.com/en-ca/download/details.aspx?id=24
Technically Microsoft doesn't support XP any longer. They don't even allow IE9 or 10 to be installed on it. _________________ "Imagination is the only weapon in the war against reality." -Jules de Gautier
evasive Mobo-fu Master
Joined: 06 May 2001 Posts: 36479 Location: Netherlands, Breda
jcn Initiate
Posted: Thu Jul 18, 2013 11:47 am Post subject: |
Thank you all for the replies; it’s taken me a while but this is what I did.
Tried to run windows update. Unsurprisingly it did not work, the error page showed suggestions to fix the problem but the page showed an error number on the top right of thee page. I used this error number in windows search and it reported the SP3 story as expected, then, a link took me to the SP3 installation page, the same one shown by Hardware Junkie above.
I downloaded SP3 on to a USB stick on this computer, as the other was unsecured. I installed SP3 to the laptop using the USB stick and tried windows update again. This time it worked, downloading and installing a large number of updates as Mr T explained.
After the above, update was run again, and again a further batch of updates was installed. I repeated this a few times until update reported that it was up to date.
When using the computer, it reported that it needed .NET Framework to work, clicked this update and now it works ok.
So thanks ALL.  _________________ ASUS P4S8X motherboard.
3GB DDR.
USB Modem for BB.
52x CD ROM Drive.
Floppy Drive.
PSU, 420 W, P4. |
Karlsweldt Enlightened Master
Posted: Fri Jul 19, 2013 7:42 am Post subject: |
Good to hear you are finally "up and running".
Yes, sadly, Win XP will be 'abandoned' next April. And the newer OS versions will not work with most older systems.. laptops or desk models. The minimal memory would need to be 1 GB or higher, and CPU speed higher than 1 GHz. Then too, disk space would need to be greater than 100 GB! Any system that won't meet the minimal specs will meet the recycling hammer of fate. Shame. Just too much "bloatware" in the newer OS versions. _________________ F@H.. to solve mankind's maladies.. in our lifetimes! |
jcn Initiate
Posted: Mon Sep 02, 2013 7:07 am Post subject: |
| Karlsweldt wrote: | Good to hear you are finally "up and running".
Yes, sadly, Win XP will be 'abandoned' next April. And the newer OS versions will not work with most older systems.. laptops or desk models. The minimal memory would need to be 1 GB or higher, and CPU speed higher than 1 GHz. Then too, disk space would need to be greater than 100 GB! Any system that won't meet the minimal specs will meet the recycling hammer of fate. Shame. Just too much "bloatware" in the newer OS versions. |
I was hoping to install Windows 7 on the system below. It's working so well and does everything I want to do: except play HD videos.  _________________ ASUS P4S8X motherboard.
3GB DDR.
USB Modem for BB.
52x CD ROM Drive.
Floppy Drive.
PSU, 420 W, P4. |
Posted: Tue Sep 03, 2013 11:18 am Post subject: |
For any video setup to display HD graphics, you need a fast "engine" and more than 512 MB of memory dedicated to it. The on-board graphics designs have no dedicated memory of their own.. but a dedicated part of the main system upper memory is set aside for that use. But the CPU has to do double-duty in processing data and rendering the video images.
For an add-in card, you have the best results.
You might get acceptable HD video if you lower the refresh rate to 70 Hz or 60 Hz. Less strain on the video engine, but also less fine detail and smooth rendering. You need minimal about 8 megs per pixel "pipeline" for each video frame. Less than 12 "pipes" for video, the poorer the effect. _________________ F@H.. to solve mankind's maladies.. in our lifetimes! |
Posted: Tue Sep 03, 2013 8:44 pm Post subject: |
jcn: what exactly is that video card since I cannot find any reference for R970 being a graphics card? _________________ We hate rut, but we fear change.
