Rudurk Pilgrim
Posted: Fri Mar 01, 2013 5:42 am Post subject: Asus Commando PSU Query |
Hi,
This Motherboard(Asus Commando) has a 24 Pin and 8 Pin Connector on the motherboard.
My power supply(Atrix 520W) only has a 24 Pin and 4 Pin Connector.
It starts the computer, but after a while(1-2 Hrs) it switches off is this a problem with the PSU or the motherboard??
I did a Memtest on my RAMs it passed with no errors... so I know its not my RAMs
So I am left with thinking is it the Power Supply thats not enough, or is the motherboard faulty... or maybe is it the Graphics card thats the culprit?
Can some one help me figure out what is actually wrong
Thanks a lot. |
Toby B. Lead Mobo-fu Master
Posted: Fri Mar 01, 2013 5:48 am Post subject: |
Your current power supply is not able to feed enough power to the board. _________________ We Help You. You Can Help Us!
Link to us from your pages |
Rudurk Pilgrim
Posted: Fri Mar 01, 2013 6:01 am Post subject: |
hmmm I see.. would that explain the pc not powering on straight away? when it switches off it takes 2 minutes to start up i mean i keep pushing the power on button(even on the motherboard) it takes 2 mins of waiting time before it starts.
and would a 720W be enough? and does it have to be a 8 Pin connector? or 4 pins will do? |
Posted: Fri Mar 01, 2013 6:16 am Post subject: |
I have honestly been out of the hardware realm for quite some time now, so the recommended wattage for your setup, I cannot really say.
As far as the auxillary power connector. If your board has an 8pin connector, you need a power supply with an 8pin auxillary cable. _________________ We Help You. You Can Help Us!
Rudurk Pilgrim
Posted: Fri Mar 01, 2013 6:38 am Post subject: |
| Toby B. wrote: | I have honestly been out of the hardware realm for quite some time now, so the recommended wattage for your setup, I cannot really say.
As far as the auxillary power connector. If your board has an 8pin connector, you need a power supply with an 8pin auxillary cable. |
Okay thanks for your help... Ill get a new PSU soon. thanks |
Mr T Enlightened Master
Posted: Fri Mar 01, 2013 6:40 am Post subject: |
List out what your system comprises of... The bigger the video card, the more power you need, the more hard drives, the more power required and so on..... And while you are thinking about, forget the cheapo brands, look at Corsair, OCZ, Antec etc, ie a decently branded one.. They have good warranty and are good steady PSU's which will last you for adding new stuff in future upgrades... _________________ I have been programming on computers since the ZX81.
Rudurk Pilgrim
Posted: Fri Mar 01, 2013 7:02 am Post subject: |
| Mr T wrote: | | List out what your system comprises of... The bigger the video card, the more power you need, the more hard drives, the more power required and so on..... And while you are thinking about, forget the cheapo brands, look at Corsair, OCZ, Antec etc, ie a decently branded one.. They have good warranty and are good steady PSU's which will last you for adding new stuff in future upgrades... |
Motherboard: Asus Commando
CPU: Q6600 (Running at stock coz anything more will not even start the dang thing)
Corsair XMS2 1GBx3
Graphics card: Radeon X1650
Zalman 9500 Cooler
Case: has a LCD
1 Rear fan
1 fan at the top
1 Side fan with lights
I built this pc like 5 years back.. and it has always had the shutting down problem...
but 4 years back I bought a 720 Watts 8 pin connector PSU for it... and plugged it in.. and it made a loud noise.. and switched off wouldn't start.
at that point i thought fudge everything in there must be dead sooo.. i left it in dust.. LOL
just 2 days back I was bored so i thought i'll give it another go and replaced the powersupply with the old original 520W PSU
and it start, but had no display (so i took out all the rams tried them one by one I had 4 of those XMS2 RAMs one of them turned out to be dead took it out and display started working) and computer start i was like the heck all this time it was the stupid PSU that was dead (at a close inspection it seems it was fault one of the pins from the 24 Pin connector was missing...( obviously i found this just 2 days back so it was already out of RMA period ) so yeah kinda my fault for not checking it 4 years back. |
evasive Mobo-fu Master
Joined: 06 May 2001 Posts: 36377 Location: Netherlands, Breda
Posted: Fri Mar 01, 2013 7:24 am Post subject: |
12KUANG JIN ENTERPRISE CO.,LTD capacitors in that Atrix power supply. Time to get yet another and now a decent-branded power supply. The caps have rested long enough to recover a bit but they are bad and will catastrophically fail at some point.
What was the brand and model on that 720W power supply? I suspect it was cheap and it may have been downright nasty built... _________________ We hate rut, but we fear change.
Rudurk Pilgrim
Posted: Fri Mar 01, 2013 7:43 am Post subject: |
| evasive wrote: | 12KUANG JIN ENTERPRISE CO.,LTD capacitors in that Atrix power supply. Time to get yet another and now a decent-branded power supply. The caps have rested long enough to recover a bit but they are bad and will catastrophically fail at some point.
What was the brand and model on that 720W power supply? I suspect it was cheap and it may have been downright nasty built... |
It was a Atrix(720W) one as well LOL it was £60 when i bought it. |
Posted: Fri Mar 01, 2013 7:59 am Post subject: |
Is that your review at Amazon UK then?
| Quote: | This is regarding the 720w version.
My offering certainly was silent... after the crackling from inside when first switched on. |
I can find other reviews that are not exactly brilliant:
http://www.overclock.net/t/1026823/atrix-extreme-power-720-watt-psu-mini-review
And you have paid waaay too much at the time. Sorry to be the bearer of bad news. If you still have that PSU, could you open it up and show what capacitors are used in there? If they have the same CS or SC stylized marking it all figures.
Their website is completely dead BTW, it is now in the hands of a domain-shark. _________________ We hate rut, but we fear change.
