mahesh Pilgrim
Posted: Thu Feb 21, 2013 8:48 pm Post subject: HMONITOR shows CPU1: Temperature above threshold, help me |
hello
i bought my PC on 2006, it's been 6 years old now.
from last 1 year i'm seeing my PC performance dieing down gradually, i really don't know the position of my CPU in performance and it's health
before i use to play heavy games on this PC, i'm a animator and my softwares will normally stress my pC, now i can't even open big files fearing the crash or restart of my PC. yes it restarts with different blue messages.
CPU = Intel(R) Pentium(R) 4 CPU 3.00GHz (2 CPUs) x86 Family 15 Model 4 Stepping 3 GenuineIntel ~3000 Mhz
MOTHERBOARD = D915GAG
RAM = 2gb
HEATSINK = 2fans, inlet and outlet
OS = XP
POWER SUPPLY = INTEX
VIDEO CARD = NVIDIA GeForce 6200 TurboCache(TM)
OEM SYSTEM = INTEL
i don't want to waste my money by going to local vendor for his guess work on my PC, which will not help my PC.
i want to help my PC in finding real problems of it and if possible replacing any peripherals, so that it performs as before.
DxDiag details is as below :-
System Information
Time of this report: 2/22/2013, 07:32:51
Machine name: SINCHANA
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 3 (2600.xpsp.080413-2111)
Language: English (Regional Setting: English)
System Manufacturer: INTEL_
System Model: D915GAG_
BIOS: BIOS Date: 02/22/06 23:50:09 Ver: 08.00.10
Processor: Intel(R) Pentium(R) 4 CPU 3.00GHz (2 CPUs)
Memory: 2046MB RAM
Page File: 490MB used, 3449MB available
Windows Dir: D:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.5512 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Sound Tab 2: No problems found.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: NVIDIA GeForce 6200 TurboCache(TM)
Manufacturer: NVIDIA
Chip type: GeForce 6200 TurboCache(TM)
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_0161&SUBSYS_00000000&REV_A1
Display Memory: 256.0 MB
Current Mode: 1024 x 768 (32 bit) (60Hz)
Monitor: Plug and Play Monitor
Monitor Max Res: 1600,1200
Driver Name: nv4_disp.dll
Driver Version: 6.14.0010.8198 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 12/10/2005 16:36:00, 3955456 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: n/a
VDD: n/a
Mini VDD: nv4_mini.sys
Mini VDD Date: 12/10/2005 16:36:00, 3536768 bytes
Device Identifier: {D7B71E3E-4221-11CF-B643-0A2000C2CB35}
Vendor ID: 0x10DE
Device ID: 0x0161
SubSys ID: 0x00000000
Revision ID: 0x00A1
Revision ID: 0x00A1
Video Accel: ModeMPEG2_A ModeMPEG2_B ModeMPEG2_C ModeMPEG2_D ModeWMV9_B ModeWMV9_A
Deinterlace Caps: {212DC724-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{212DC724-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{212DC724-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{212DC724-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
http://imageshack.us/a/img189/9237/hmonitor.png
evasive Mobo-fu Master
Joined: 06 May 2001 Posts: 36375 Location: Netherlands, Breda
Posted: Thu Feb 21, 2013 10:32 pm Post subject: |
What is the exact make and model of the power supply? i suspect something is wrong in there if the system becomes unstable under stress.
By all means the CPU message is likely from having dust bunnies in the heatsink/fan on the CPU so it's not cooling enough.
The message in your picture is from a dead CMOS battery, have the 3V lithium coin cell (type CR2032) replaced with a fresh new one. _________________ We hate rut, but we fear change.
Hardware Junkie Mobo-fu Master
Joined: 25 Jan 2001 Posts: 19349 Location: 00000h - 0000Fh
Posted: Fri Feb 22, 2013 9:34 am Post subject: |
I have also seen a few cases where the stock thermal paste that comes with Intel CPUs drys out or becomes inadequate.
I'd open the case while the system is on, see if the fan is even spinning fast enough. Check your BIOS if it can detect FAN speeds.
Hardware Monitor here:
http://www.cpuid.com/softwares/hwmonitor-pro/versions-history.html
Could give you some reliable info, including temps and fan speeds.
If they seem to be crappy, pull off the headsink, and inspect. If its caked in dust, I've gone to the extreme of pulling off the electric components and giving the metal part a bath before.
Reapply new fresh thermal paste, re-attach and see if that helps.
Evasive is probably right on the dead cmos battery. And a cheap or dying power supply could also explain some of what you are getting. _________________ "Imagination is the only weapon in the war against reality." -Jules de Gautier
Roach412 Black Belt 2nd Degree
Joined: 09 Aug 2004 Posts: 2456 Location: Milwaukee - Wisconsin
Posted: Fri Feb 22, 2013 10:50 am Post subject: |
i also agree with the CMOS and PSU. the battery is a 5 minute fix, so give that a try. the PSU is a little more investment - and might want to consider upgrading rather than continuing to invest in something 6 years old. i mean, i like my old computer too, but...6 years is getting close to end of useful life. multiple other components are going to most-likely be getting close to end-of-life as well.
-Roach _________________ Lian Li Lancool First Knight Series PC-K59W
EVGA GTX 560ti FPB
Crucial M4 128gb SATAIII SSD
Corsair Professional Series HX850 PSU |
