bdub Black Belt 3rd Degree
Joined: 19 Feb 2003 Posts: 3328 Location: Washington D.C.
Posted: Tue Feb 19, 2013 10:23 am Post subject: |
under boot tab, and boot device priority, what happens when you hit the different buttons there? do you see a list of devices to boot from? _________________ my main rig...
asrock 970 extreme3
AMD athlonII X3 440
zalman cpns5x performa hs/fan
antec neo he 650r
kingston hyperx 3k ssd 120GB
seagate 500GB HDD 32M cache
seagate 750GB HDD 32M cache
hitachi 1TB HDD 32M cache
lg wh14ns40 bd burner
Posted: Tue Feb 19, 2013 10:27 am Post subject: |
getting back to the bios update thing,
http://support.asus.com/download.aspx?SLanguage=en&m=P5Q+PRO&os=29
you may want to update your bios as it may give you more choices to boot different things. the latest is 2101 from may 2009. _________________ my main rig...
asrock 970 extreme3
AMD athlonII X3 440
antec neo he 650r
Posted: Tue Feb 19, 2013 10:32 am Post subject: |
seems the SI controller has some instruction coming from the "tools" tab.
under drive xpert control... what is the condition you see there, and what if you change the settings?
i admit it is weird, i never like asus... _________________ my main rig...
asrock 970 extreme3
AMD athlonII X3 440
antec neo he 650r
vic_salve Initiate
Posted: Tue Feb 19, 2013 10:35 am Post subject: |
Ok, with drive containing OS connected to silicon image controller and two new drives connected to Intel controller, I can boot as long as the storage configuration is set on IDE. When I change this to RAID and then go to boot setup. I see all drives, but they are listed as RAID. This includes drive that is connected to silicon image controller.
Under tools....express gate is disabled.
Going to work on updating BIOS
Posted: Tue Feb 19, 2013 10:40 am Post subject: |
on the main page, under system configuration, you should see what version bios you have.
also on the main page, when intel controller is in ide mode, do you see the boot drive listed as one of those six drives headings there? _________________ my main rig...
asrock 970 extreme3
AMD athlonII X3 440
antec neo he 650r
vic_salve Initiate
Posted: Tue Feb 19, 2013 10:47 am Post subject: |
BIOS ver 0602
And yes, the boot drive is listed last under SATA_E1
By the way I just noticed that this motherboard is a P5Q PRO Turbo.......not just P5Q PRO
Sorry about that. |
vic_salve Initiate
Posted: Tue Feb 19, 2013 11:35 am Post subject: |
Finished updating BIOS, Everything looks the same And same issues still apply.
I did notice when configuration was in RAID when entering Intel matrix storage manager there were 3 drives listed and the drive containing the OS is one of them. With this drive being physically connected to the SI controller I wouldn't think it should be listed there, but there she be! |
Posted: Tue Feb 19, 2013 11:37 am Post subject: |
well there are differences, that has a jmicron pata/esata controller instead of the marvell ide controller.
but the drive xpert thing is still there. have you messed with those settings?
if there is no way to get the SI controller to be a bootable device while the intel controller is in raid mode, then you are going to have to get the os booting off the intel controller, and i think evasive was pointing to that earlier.
it's just incredible that there is no way to boot off the Si controller, though... makes no sense, but that's asus for ya. _________________ my main rig...
asrock 970 extreme3
AMD athlonII X3 440
antec neo he 650r
Posted: Tue Feb 19, 2013 11:39 am Post subject: |
are you absolutely sure you are attached to the non-intel controller ports? what if you move them around?
i haven't dl'd the turbo manual yet, but hopefuolly later i can dig into it some... i'd suggest you fool around on that "tools" menu to see what effect that has on the SI controller state.
or if you have ghosting skills, you can ghost to a pata drive, then boot to that, and turn the intel controoler to raid mode, then install your riad driver, then ghost back to the boot drive on the raid controller.
or find a way to get the raid driver installed on your current boot drive somehow, which i think evasive was hinting at. _________________ my main rig...
asrock 970 extreme3
AMD athlonII X3 440
antec neo he 650r
vic_salve Initiate
Posted: Tue Feb 19, 2013 11:58 am Post subject: |
Yea, I'm connected to the SI controller. I've checked that several times. It's even a different color. I checked it again just to make sure I'm not going to look like a (insert favorite doofus moniker here).
As for ghosting, have never tried that. |
