vic_salve Initiate
Posted: Mon Feb 18, 2013 8:20 pm Post subject: Raid 1 Config |
Hello,
Okay. I have a PC in the basement that I use to run the surveillance system of the house. This PC is on 24/7.
Windows XP Pro
Asus P5Q PRO motherboard
2 WD 500 gig drives
On one drive is the O/S and software and storage for the surveillance card and nothing else of importance.
The other drive I have always used for storage of important files. This drive is networked and I access it as need to place those important files.
Time passes and the drive fills up. I have a great idea. I'll purchase two new drives, install them in the basement PC, set them up in RAID 1, transfer important files to the new setup, and now not only do I have more storage, but my files are mirrored and safer than ever.
Seemed like an easy enough process and thought I knew what to do. I intended in not changing the O/S drive at all and continue on my happy way. Unfortunately, I'm having trouble. I am unable to get it going as planned.
I changed to raid in bios set up a raid 1 volume and tried to reboot. Now the O/S drive is not able to be set up as the boot disc. Now I'm tired and look to more experienced folks for help.
I guess the first question is can I change the bios storage configuration from ide to raid? There are two different types of SATA connectors on this motherboard. One supports raid the other does not. The O/S drive is connected to the SATA that does not support RAID.
Thanks in advance for input!
Vic |
evasive Mobo-fu Master
Joined: 06 May 2001 Posts: 36382 Location: Netherlands, Breda
Posted: Tue Feb 19, 2013 2:01 am Post subject: |
Make either of the driver disks in the bottom of this list (yes, that means using a floppy drive! ) and press F6 during the textmode phase of windows XP setup, then feed it the disk. XP has no idea by itself what SATA RAID looks like, you need to give it the mass storage controller drivers first.
http://www.asus.com/Motherboard/P5Q_PRO/#support_Download_17 _________________ We hate rut, but we fear change.
bdub Black Belt 3rd Degree
Joined: 19 Feb 2003 Posts: 3328 Location: Washington D.C.
Posted: Tue Feb 19, 2013 7:31 am Post subject: |
if you are booting off the silicon image controller, then anything you do to the intel controller is not going to affect the boot drive at all. you should be able to change the intel controller to raid, have the system start, and it should tell you it needs a driver for the new mode of the intel controller, from within the OS.
the only problem i see that could occur is if something important to the boot drive was lost when the intel controller was changed. maybe there was a bootmanager, or dual boot routine that resided on the intel controller at one time? something tying the boot drive to the data drive somehow, and it is not there when you change the mode on the intel controller.
check your boot order.... yes that is first to check. and make sure you are still set to boot from silicon image controller first in bios.
but beyond that you should be good to go, unless there is some anomaly like i described above. _________________ my main rig...
asrock 970 extreme3
AMD athlonII X3 440
zalman cpns5x performa hs/fan
antec neo he 650r
kingston hyperx 3k ssd 120GB
seagate 500GB HDD 32M cache
seagate 750GB HDD 32M cache
hitachi 1TB HDD 32M cache
lg wh14ns40 bd burner
Posted: Tue Feb 19, 2013 7:36 am Post subject: |
aww, misread on my part.
Vic,
Power down, disconnect the data cables from the new drives and any other additional drives so just your original OS drive is still attached, power on. Does it boot? _________________ We hate rut, but we fear change.
vic_salve Initiate
Posted: Tue Feb 19, 2013 8:00 am Post subject: |
| evasive wrote: | aww, misread on my part.
Vic,
Power down, disconnect the data cables from the new drives and any other additional drives so just your original OS drive is still attached, power on. Does it boot? |
Okay. I have disconnected all drives except the drive containing OS. This drive is connected to the SATA_e1 silicon image serial ata connector. It did start up and boot as normal.
Only difference is that this drive was originally connected to the ICH10R serial ata connector SATA1 or maybe SATA2 connector.
Thanks |
vic_salve Initiate
Posted: Tue Feb 19, 2013 8:11 am Post subject: |
bdub,
The drives were originally connected tot he intel controller. I moved the drive containing the OS over to the silicon image controller and tried to set everything up in the bios accordingly. I can get PC to boot while sata configuration is set to IDE, but when I switch to RAID I can no longer boot from the drive with the OS. I'll check, but I believe when I switch to RAID in bios I'm no longer able to choose the silicon image controller as the first to boot.
Thanks for the help. Still trying to figure it out. |
Posted: Tue Feb 19, 2013 9:31 am Post subject: |
look carefully, there should be a way to boot from a drive on the SI controller no matter what condition the intel controller is in. there may also be a seperate SI boot post page you can adjust to mark a boot device, or something like that.
i'll dl your manual to get more familiar.
havve you updated the bios to the latest?
strange, i can't get to the download section for your motherboard.... _________________ my main rig...
asrock 970 extreme3
AMD athlonII X3 440
antec neo he 650r
vic_salve Initiate
Posted: Tue Feb 19, 2013 9:57 am Post subject: |
I have not updated bios. As a matter of fact it is original as delivered. Never was interested in updating since the pc was just specific use and never had any trouble with it. I have always been a little apprehensive in updating the BIOS.
I will look again at the bios and see if I can find something different that I may have missed. |
Posted: Tue Feb 19, 2013 10:06 am Post subject: |
looking for SI controller... in bios... hmmm... _________________ my main rig...
asrock 970 extreme3
AMD athlonII X3 440
antec neo he 650r
vic_salve Initiate
Posted: Tue Feb 19, 2013 10:18 am Post subject: |
Under on board devices configuration, I do not have Marvell ide option.
Only have "controller mode. [IDE]" and this can only be changed to AHCI |
