boheemee Black Belt
Posted: Fri Feb 15, 2013 9:22 pm Post subject: |
I have to agree with evasive, bad caps are still a big problem. I just finished recapping my Acer LCD monitor. 6 bad caps on the power board. Here's a reference to a monitor like yours on the bad caps forum.
http://www.badcaps.net/forum/showthread.php?t=14300 _________________
Karlsweldt Enlightened Master
Posted: Sat Feb 16, 2013 3:32 pm Post subject: |
Possible that Windows has done its "thing" again, and optimized the monitor connection beyond its limit? Try a setting for refresh rate at 70 Hz.
If you have a good image when in the BIOS, but after Windows starts you loose the image, very likely. But if an unstable image when in the BIOS, very likely the monitor itself is experiencing the backlight failure syndrome. Your model (and similar) should have a VGA as well as a DVI video port. So possibility of testing on another system is an option. But as you mention 'flickering', that points to either the backlight tubes failing or their power inverter. They require around 150 volts to become active, then the voltage falls to around 60 volts or so (in-circuit load resistor) to keep them lit. The inverter board may have suffered a mild heat extreme, and is in failure mode. If that in-circuit load resistor has gotten too warm, it can pass heat to the solder connections.. and melt them! _________________ F@H.. to solve mankind's maladies.. in our lifetimes! |
BIGMAN131307 Black Belt 2nd Degree
Joined: 07 Aug 2001 Posts: 2152 Location: " Say 'ello to my little friend! "
Posted: Mon Feb 18, 2013 11:04 am Post subject: |
I tried onboard video connection. The computer powered on, but nothing appeared on the monitor at all.
I turned off my PC, and connected the monitor back to the videocard again. When I started my PC, it loaded fine for a few minutes. Then it froze on me. It took three attempts to get the monitor to keep working.
Now the monitor started to flicker very badly like a strobe light. I tried a restart, but it flickered at the very start. As a last resort I disconnected my 23" monitor. I am currently stuck using my old 17" monitor.
_________________________________________________
What do you recommend I do with the other one? Should try getting it repaired from Samsung? What about Geek Squad, do they even do repairs like this?
All I know for sure is this smaller monitor isn't going to useful for long.
I need the larger monitor. _________________ GO GREEN |
evasive Mobo-fu Master
Joined: 06 May 2001 Posts: 36407 Location: Netherlands, Breda
Posted: Tue Feb 19, 2013 12:56 am Post subject: |
You should inform Samsung that it is behaving like this, they may have some sort of extended warranty because of the bad capacitor problem (mention you suspect it has that problem). I remember seeing something similar for some of their TV sets a while ago. _________________ We hate rut, but we fear change.
Posted: Tue Feb 19, 2013 1:55 am Post subject: |
I've checked with them. It would cost me at least $80-$150? There was no specific price given. That doesn't even include the shipping cost to & from the service center.
A new monitor lost like the best option. This one was 2 yrs 9 months old. _________________ GO GREEN |
Posted: Tue Feb 19, 2013 3:32 am Post subject: |
wow. You could try and put it on ebay with the note it's defect and you suspect it has bad capacitors. _________________ We hate rut, but we fear change.
