A Motherboard to read and write RFID Tags
Postby Fluggey » Mon Feb 11, 2013 12:42 pm
Hi
I'm looking for a Motherboard to read and write RFID Tags that can be used with the iPhone 4, 4s and 5.
Can anybody please suggest a board that can be used with the iPhone 30 pin connector and also used with the new lightning pin connector.
Thanks.
Fluggey
Postby Hardware Junkie » Mon Feb 11, 2013 7:22 pm
This has been posted at quite a few sites. I would recommend you use google. I was able to find a supplier for what your looking for.
https://www.google.ca/search?q=read+and+write+RFID+Tags
Return to Tech Support
