WinXP dead install or dead HDD?
Goto page Previous  1, 2, 3, 4  Next
PostPosted: Sat Feb 09, 2013 6:01 am    Post subject: Reply with quote
before you go there, please run this:
http://www.majorgeeks.com/MBRCheck_d7076.html
I have a funky feeling about this...
rascard2007
PostPosted: Mon Feb 11, 2013 8:04 am    Post subject: Reply with quote
You can take a look at www.hddguru.com, there are some toolt to deal with HDD´s and some good info also.
-Wrapped Around Your Fingers-
-The Police-
OldPhatDad
PostPosted: Mon Feb 11, 2013 2:33 pm    Post subject: Reply with quote
Ran it: 'Windows XP MBR code detected' reported in green lettering.
Is there something further I need to do with the SHA1 number that was reported?
Antec Nine Hundred
Intel C2D E6750 @ 3.6 Ghz
Gigabyte P35 DS3L
Mushkin Redlines 2 x2GB kit
EVGA GTX 260 Core 216 896 MB
WD 250 GB SATA2
Seagate 160 GB SATA
WD 500 GB SATA2
Thermalright Ultra 120 Extreme
PC P&C Silencer 750W
Windows XP SP3
bdub
PostPosted: Mon Feb 11, 2013 3:30 pm    Post subject: Reply with quote
are you still experiencing that you cannot get to the repair section on your xp install disc?
if somehow you can get that repair section to show up, you could goto command prompt and do a "fixmbr" or "fixboot", maybe?
http://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/bootcons_fixmbr.mspx?mfr=true
and possibly "diskpart" could help by activating the c drive partition.
but if you don't see the repair option anywhere, that is weird. must have something to do with how your sata controller is set up. maybe you have to load an "f6" driver to get the drive to show up, thereby giving you repair option? is the xp install disc you are using included to have sp3 fixes, or might it be an original no-sp, or sp1, sp1a, sp2 disc?
my main rig...
asrock 970 extreme3
AMD athlonII X3 440
zalman cpns5x performa hs/fan
antec neo he 650r
kingston hyperx 3k ssd 120GB
seagate 500GB HDD 32M cache
seagate 750GB HDD 32M cache
hitachi 1TB HDD 32M cache
lg wh14ns40 bd burner
PostPosted: Tue Feb 12, 2013 1:22 am    Post subject: Reply with quote
Nope. It's fine.
rascard2007
PostPosted: Tue Feb 12, 2013 8:10 am    Post subject: Reply with quote
try a look at:
http://www.michaelstevenstech.com/repair_install_warning.htm
and here:
http://www.techrepublic.com/article/10-things-you-can-do-when-windows-xp-wont-boot/6031733
-The Police-
OldPhatDad
PostPosted: Wed Feb 13, 2013 7:23 am    Post subject: Reply with quote
I've tried both my original disc, which is SP 1a, and a slipstreamed disc that has SP2 integrated into it.
I can't try the F6 option, as I have no floppy drive.
rascard2007 wrote:
try a look at:
and here:
Looked at those, thanks. Unfortunately, the few things I can try in the list in the second link don't work, and I can't try the others since I can't get the machine to boot either normally, in Safe Mode, Last Known Good Configuration, or from the XP disc.
Trying to boot from the disc I get the normal load info (Setup is Loading Files), then it immediately goes to Setup Is Starting Windows and I get the stop error right away. I never get any options at all (no repair option, no install XP option, nothing).
I guess this installation is hosed and I'll have to just start anew. I can't see any other options.
Thanks guys, for all the help.
Antec Nine Hundred
Gigabyte P35 DS3L
WD 250 GB SATA2
Seagate 160 GB SATA
WD 500 GB SATA2
Windows XP SP3
PostPosted: Wed Feb 13, 2013 11:05 am    Post subject: Reply with quote
Ensure that the date/time is correct. Go into the BIOS and adjust if needed so the setting is right. Have seen a few XP installs that balked at fully loading, if the date and time were much older (months) than the last boot up!
This can happen too, if the date and time were somehow advanced beyond "real" time and then you try to reboot in actual time! System files would have a time/date stamp, but to note them you would have to mount the drive in another system as secondary!
OldPhatDad
PostPosted: Wed Feb 13, 2013 11:22 am    Post subject: Reply with quote
Thanks, Karl, but I made sure it was correct a several attempts back.
Antec Nine Hundred
Gigabyte P35 DS3L
WD 250 GB SATA2
Seagate 160 GB SATA
WD 500 GB SATA2
Windows XP SP3
OldPhatDad
PostPosted: Wed Feb 13, 2013 11:41 am    Post subject: Reply with quote
AHHHH!!! Stupid, stupid, STUPID! I think I figured it out. Stupid me, I have 3 hard drives in this rig, one for data and one for backup. Anyway, all this time I was booting and re-booting and screwing around with all three drives connected. I installed a brand new blank drive and tried to install XP on it and still got the stop error. So then I finally grabbed a clue and unhooked the extra drives.
XP fired up from the disc no problem and gave me the option to install or repair. Then I switched in my old hard drive that has the OS installed and LO! it booted without issue. So I think one of my other hard drives is bad and that's what was causing the boot issues. And I think I know which one it is. Ye gods, I can't believe I was so stupid as to not disconnect those first thing just to isolate the system. Stupid, stupid, stupid.
Anyway, thanks once again everyone for all the help and sorry to waste so much of your time.
Antec Nine Hundred
Gigabyte P35 DS3L
WD 250 GB SATA2
Seagate 160 GB SATA
WD 500 GB SATA2
Windows XP SP3
Page 3 of 4
