msi p35 neo2-fr
sscottab
PostPosted: Sat Jan 19, 2013 4:41 pm    Post subject: msi p35 neo2-fr Reply with quote
i recently bought the msi p35 neo2 fr with the intel e6750 core 2 duo processor the ram is 4 sticks of 512 ddr2 5300 the problem iam haveing is when i go into the bios i can see everything including the sata hard drive it is a new 500 gb maxtor, when i go to load it goes through the boot screen shows the bios version 1.1.0.L69 then states initalizing then states no hard drive detected so i removed the hard drive and put it in another older desktop and installed vista on it with no problems put it back into the orginal one now it still states no hard drive detected then i get the screen to start in safe mode or start normanaly the os tries to boot then quisct blue flash and starts over again iam getting frustrated please help.
thank you
scott
bdub
PostPosted: Sun Jan 20, 2013 6:05 pm    Post subject: Reply with quote
if you are putting xp on it, then you need to load the "f6" driver for the install to see the drive... or maybe that mobo has an "ide" mode for the hdd controller, which you would set in the bios.
and possibly the same with vista... it may not have the driver built in that it needs. win7 would prolly have no problems.
that quick blue flash is a blue screen of death, and is happening probably because you are trying to load an OS that was built in another machine. sometimes it works, mostly it doesn't.
if you look in the bios at "integrated periphials"...
then at "onchip ata devices"...
look at the "raid mode" setting... if on IDE, you should be able to load the os pretty easily, but you lose whatever bells and whistles that sata drive has to offer. raid or ahci modes might need the "f6" driver i was talking about. it would be prudent to try to get it in at least ahci mode, if you can get the driver... pretty sure vista lets you use a flash drive to install it.
it is also possible you are putting the drive on the extra controller (marvell) that is in there, and vista needs that driver to recognise the hdd.
looks like you might need the driver either way (after looking in the manual)... you might as well be in raid mode.
here's the link to the driver you will need.
http://www.msi.com/service/download/driver-17380.html
unzip the folders in another machine, and put put the contents of either the x64 or x86 folders (depending on which version of vista) on a flash drive that is formatted FAT32, and plug that in when the OS install asks for it (probably the same area where it is saying "no hdd detected").
you should be able to browse the flash drive to get there.
make sure you are using one of the intel sata ports, the marvell will not do you any good, unless you find the driver for it.
my main rig...
asrock 970 extreme3
AMD athlonII X3 440
zalman cpns5x performa hs/fan
antec neo he 650r
kingston hyperx 3k ssd 120GB
seagate 500GB HDD 32M cache
seagate 750GB HDD 32M cache
hitachi 1TB HDD 32M cache
lg wh14ns40 bd burner
Page 1 of 1
