elduderino Initiate
Posted: Sat Dec 08, 2012 9:01 am Post subject: Packard Bell Easynote SATA drivers help |
Hi
I have an Easynote Laptop. The only info i have is that it is an MX37 model. Vista Basic O/S.
I need the SATA drivers to re-install O/S
link to driver downloads, but there are no SATA drivers listed, can someone help please.
The web page takes a while to load.
ftp://ftp.download.packardbell.com/NOTEBOOK/EasyNote%20MX37%20series/Driver/Vista/
Thanks |
Ripshod Black Belt
Joined: 13 Aug 2003 Posts: 703 Location: Yorkshire, UK
Posted: Sat Dec 08, 2012 3:32 pm Post subject: |
Do you realise this laptop was part of a batch recalled due to faults?
I would have assumed that vista would have the drivers by default
This is one for the more senior members. Just letting you know you're not being ignored  _________________ CALL &BD19 (If you need to ask you don't need to know)
elduderino Initiate
Posted: Sun Dec 09, 2012 12:44 am Post subject: |
Hi
Thanks for the reply, & info
Did not know that the laptop had faults. It 4 years old, with no problems yet, so their takin their time appearing.
The existing HDD is 120GB SATA. Just found out that the BIOS don't recognise anything above(Wanted to increase the size of HDD) 120GB.
Thats why there aint any SATA drivers.
Just have to keep on using the existing HDD. |
Ripshod Black Belt
Mr T Enlightened Master
Posted: Sun Dec 09, 2012 4:32 am Post subject: |
4 years old - it should see a drive well above 120Gb, esp if it is running Vista. Have you gone into the BIOS and enabled 'IDE mode' rather than ACHI mode? This enables you to install the OS without the ACHI drivers. _________________ I have been programming on computers since the ZX81.
Hardware Junkie Mobo-fu Master
Joined: 25 Jan 2001 Posts: 19351 Location: 00000h - 0000Fh
Posted: Mon Dec 10, 2012 8:08 am Post subject: |
Mr T is on the money to get the OS reinstalled. The only issue is it may affect performance of the laptop.
We might be able to find the right drivers, but we need a more specific model number. Look on the bottom, you should see something like MX37-S-200 or similar.
I've seen people reference MX37s with SiS and Intel chipsets. _________________ "Imagination is the only weapon in the war against reality." -Jules de Gautier
Karlsweldt Enlightened Master
Posted: Tue Dec 11, 2012 6:14 am Post subject: |
Should be a small, hidden partition on the original hard drive.. which contains the drivers and install setup. Typically, when you first use the computer, you are prompted to copy that partition to an optical disk.. for future reference. Use the Disk Manager feature of System Tools to activate that partition (if still there) so it can be accessed and copied to an optical disk. Likely it is around 500 megs or so.. possibly including the OS intended for the system.
You could use a free diagnostics program such as CPU-Z to ID the basics of the laptop.. such as processor type, memory and chipsets. Get it from http://www.cpuid.com/cpuz.php . _________________ F@H.. to solve mankind's maladies.. in our lifetimes! |
Dillon88 Pilgrim
Posted: Sat May 04, 2013 3:30 am Post subject: |
| SATA hard drive to substitute the IDE drives increasing speed offer. SATA HDD have prices low instead of an IDE. Install window adn applications on SATA drives provide more speed which determines to run system, then SATA support extra step is required to install Window XP, during the installation procedure that must insert a floppy with drivers with the motherborad. |
