Bolgan Green Belt
Posted: Sat Dec 01, 2012 1:00 pm Post subject: Hdd not detected |
Hi there,
My internal hdd Shows in the List of serial ata Devices in the BIOS screen
But is not showing in the List of bootable Devives in the BIOS Setup
I have tried different cables etc, but no luck
Anything idea what the Problem could bei? |
Karlsweldt Enlightened Master
Posted: Sun Dec 02, 2012 1:48 pm Post subject: |
More info is needed.. such as BIOS date of the system, and if it is SATA-1 or SATA-2 qualified. Older SATA designs may not recognize newer SATA-2 or SATA-3 devices. Check the details on the drive's label as to status, and if a jumper needs to be set to default to older standards.
If a new, unformatted drive, then use the OS install disk to partition and format it. If set as a secondary drive in a working system, use the Disk Manager feature of System Tools to partition and format it. _________________ F@H.. to solve mankind's maladies.. in our lifetimes! |
evasive Mobo-fu Master
Joined: 06 May 2001 Posts: 36375 Location: Netherlands, Breda
Posted: Sun Dec 02, 2012 11:47 pm Post subject: |
What brand/model is your motherboard? Is the disk connected directly to the board or to an add-in controller card? If on the card, did you buy one with a seperate bios to enable booting from it? _________________ We hate rut, but we fear change.
rascard2007 Anti-Static Strap
Joined: 12 Jun 2007 Posts: 411 Location: Havana, Cuba
Posted: Mon Dec 03, 2012 8:07 am Post subject: |
moboīs Brand & model needed.
some bios have two inputs related to booting devices. in the fisrt one U choose what devices to boot and in the second one you choose the boot order.
if U donīt list ur disk in the first entry them it will be not available in the second _________________ "I have only come here seeking knowledge,
-Wrapped Around Your Fingers-
-The Police- |
