CCTV DVR Motherboard?
Postby ed4586 » Thu Nov 29, 2012 4:48 pm
I know it's not a PC based motherboard but...
I have a Qsee QT428 DVR recorder for my home cctv security system, looks like the motherboard is gone. Noticed one of the "tiny" fusible links is fried, and wiggling of the cables indicates a bad connection (picture flickers)....checked all of the soldered points and can't ID any broken soldered points.
Tried searches of the part number (in the picture) and only learned that it is a generic board used by several DVR producers.
Have never had any luck with Qsee support either...have any idea where I might find one?
ed4586
Postby evasive » Fri Nov 30, 2012 12:35 am
2308SE is even a generic part number for the box, not just the motherboard. the brand seems to be TVT:
http://www.cctvforum.com/viewtopic.php? ... 4&start=15
but the Q-see QT428 is in fact a TVT TD-2308SE motherboard inside the q-see QT428 box
http://en.tvt.net.cn/support.aspx?TypeId=16
Maybe they can help you out better than Qsee
Postby ed4586 » Mon Dec 03, 2012 10:59 am
Thanks evasive
Appears that I'll need write a letter to Qsee, their online support page had no land line info and their online message systems wasn't working.
Obviously..I'll never buy another Qsee product.
ed4586
Postby evasive » Tue Dec 04, 2012 2:15 am
Right... Does TVT have presence outside China? I didn't check...
Postby Hardware Junkie » Wed Dec 05, 2012 11:02 am
evasive wrote:Right... Does TVT have presence outside China? I didn't check...
Doesn't look like it. They may have reps, but all the support is based out of China.
