Laurakitty Pilgrim
Posted: Wed Nov 28, 2012 10:15 am Post subject: Acer DA061L Boxer AM2 61 - Broke SATA pins |
| On my Acer DA061L Boxer AM2 61 motherboard, the SATA connector pins are broke. What should I do? |
bdub Black Belt 3rd Degree
Joined: 19 Feb 2003 Posts: 3328 Location: Washington D.C.
Posted: Wed Nov 28, 2012 10:24 am Post subject: |
if the connector on the motherboard is physically damaged, there's not much recourse but change to another port that isn't damaged... if ALL of them are broke, you need to use another way to attach hdd's to your system, and that is a card that plugs into one of the open expansion slots on the motherboard. or possibly use an esata port on the back i/o area, if there is one.
from what i can see, there are two sata ports on that mobo. are they both physically broken (snapped off)? _________________ my main rig...
asrock 970 extreme3
AMD athlonII X3 440
zalman cpns5x performa hs/fan
antec neo he 650r
kingston hyperx 3k ssd 120GB
seagate 500GB HDD 32M cache
seagate 750GB HDD 32M cache
hitachi 1TB HDD 32M cache
lg wh14ns40 bd burner
Laurakitty Pilgrim
Posted: Wed Nov 28, 2012 10:42 am Post subject: |
| Nope. Just the plastic covering and the pins on SATA 2 are all broke off. Will I need to replace the motherboard? |
Posted: Wed Nov 28, 2012 11:05 am Post subject: |
http://www.ebay.com/itm/Acer-DA061L-Boxer-61-Motherboard-08120-1-AM2-MB-G1001-001-/330647005835
in this picture there are two sata ports... one is above the ram clasp (as pictured), and the other is to the right of that ram clasp. you don't have both those ports? _________________ my main rig...
asrock 970 extreme3
AMD athlonII X3 440
antec neo he 650r
Laurakitty Pilgrim
Posted: Wed Nov 28, 2012 11:23 am Post subject: |
| Yes. |
Posted: Wed Nov 28, 2012 11:35 am Post subject: |
well, then you either need a pci-e card that has an internal sata connector to run to the hdd (you will also have to re-install the OS, most likely, but maybe not)... or, yes, another mobo will do. maybe someone has a trick to fixing those ports, but they are factory soldered, and very hard to replace.
there's also the possibility of attching that hdd to the esata port on the back i/o area... if there is an esata port back there. _________________ my main rig...
asrock 970 extreme3
AMD athlonII X3 440
antec neo he 650r
Karlsweldt Enlightened Master
Posted: Wed Nov 28, 2012 1:31 pm Post subject: |
If the pins have broken off, it is possible to replace the socket for a SATA port. But you would need to purchase a new socket from an electronics supplier, or scavenge one from a bad board. Then the problem of ensuring the connections are proper. The sockets are keyed with a 'lip' on one end of the tongue in the slot, to match the cable plug. You would have to note another exact board model to determine how the sockets are oriented.
Would be less of a hassle to just add a device card, and disable the on-board feature. _________________ F@H.. to solve mankind's maladies.. in our lifetimes! |
