White and Yellow wires in NMB-MAT fan
Postby mxmone » Fri Nov 30, 2012 3:28 pm
Thanks for links. One of them leads to FAS (I have DS14) but I found this: http://www.andovercg.com/datasheets/net ... -guide.pdf In PDF there is no word about fans in PSU ;) Problem with fan? Replace whole PSU :P
I also know about nmbtc.com site. That's why I know all about cables and signals in fan. Yellow cable is PWM, but this is not a PWM from normal computer. He has 200Hz... Standard PWM have 25kHz (from PDF specs). But to find out what are the real shapes of signals I must buy oscilloscope. On ebay costs only 75,80$ DSO201 ;) I do not have to have a very good oscilloscope. This toy will do the job :)
Fans I intend to mount, are very quiet. This is Nocuta so even at full speed they will run quieter than previous fans at low speed.
mxmone
Previous
Return to Tech Support
Users browsing this forum: SemrushBot [Bot] and 1 guest
