v2dp mobo
Michaeljay2
PostPosted: Sat Nov 24, 2012 3:27 pm    Post subject: v2dp mobo Reply with quote
This mobo has a weird problem, it won't load the unichrome video drivers I obtained from the manufactures site, it loads all the other drivers with no problem. Would this indicate that the mobo is bad? it's running an amd2200 processer with 2 gigs of mem and the bios information is 11-23-2004-km266pro-8235-km400/km266pro phoenix-award bios v 6.00pg.
Does anyone have any input to this problem?
PostPosted: Sat Nov 24, 2012 3:38 pm    Post subject: Reply with quote
What OS version are you using? And are the drivers signed digitally in accordance with the OS provider's agreement? Drivers for the latest OS versions of Windows must meet the WHQL vendor list of product quality.. or they may be rejected. And certain driver types cause interference with other programs.
If the OS has installed its own set of drivers for a device, they may be appropriate.. but not exact for best performance. If the OS balks at the install, then insist (force) the OS to accept them.
If a previous video device is similar (chipset wise) to a new video device, then the old drivers must be uninstalled and the device removed from the hardware lineup. Shut down, remove or disable the old device and install the new device.. then boot up with the driver disk available in a drive unit. The OS should do a search for "new" features and drivers automatically.
PostPosted: Sat Nov 24, 2012 10:24 pm    Post subject: Reply with quote
Check for leaking or bulging capacitors. Motherboards from that era are really prone to them. If it is an old PSU, get a torch and check that out too..
Check http://www.badcaps.net/ out...
Michaeljay2
PostPosted: Sun Nov 25, 2012 11:12 am    Post subject: Reply with quote
I'm using XP Pro and windows installed a generic driver. The downloaded files from the manufacture installed with no problem and were diglitly signed. The file name of the problem file is Prosavage DDR_wxp_139433. When I run setup it starts up fine then says it can't complete the install. From device manager's update driver or add device it comes up with an not compatilble error. There were a few poped electroletic caps and they were replaced with the same value uf at a higher volts.
I am an electronic tech but old school and have been building/repairing and setting up computers since the day's of the 8088 cpu's.
kokalo
PostPosted: Mon Nov 26, 2012 1:12 am    Post subject: Reply with quote
What has me confused is the string in the filename... wxp is obvious and 1394 stinks like FireWire err.... IEEE1394 - is it using the wrong file or is the filename just a coincidence....
If it wasn't a UniChrome I'd suggest throw Linux at it, even just a live distro, but with spotty support for UC graphics that may turn out inconclusive...
On the other hand, chipset is old enough that W7 or even Vista should have basic drivers for it, maybe try that, throw in a blank drive and load a trial... If W7 spits the dummy at it, I think you can safely stop wasting time and replace the board.
P3! (No, not PIII)
PostPosted: Mon Nov 26, 2012 2:56 am    Post subject: Reply with quote
Jetway board:
http://www.jetway.com.tw/jw/motherboard_view.asp?productid=34&proname=V2DP
Drivers specific for this board:
Replace with low-ESR caps please, otherwise the cure is worse than the problem...
http://en.wikipedia.org/wiki/Capacitor_plague
Michaeljay2
PostPosted: Mon Nov 26, 2012 8:25 am    Post subject: Reply with quote
I tried the jetway site, downloaded the video driver and came up with the same error cannot complete the install. setup only starts up, it doesn't even begin the real install and the replacment caps I use are from other bad mobos with good caps. I have several dozen around and I guess I will have to add another. lol
bdub
PostPosted: Mon Nov 26, 2012 8:39 am    Post subject: Reply with quote
cheap agp or pci card to run the graphics could work, and then see if you can turn onboard graphics off in bios.
as i recall, those old onboard chips from that era can't drive widescreen monitors at proper resolutions anyhow.
my main rig...
asrock 970 extreme3
AMD athlonII X3 440
zalman cpns5x performa hs/fan
antec neo he 650r
kingston hyperx 3k ssd 120GB
seagate 500GB HDD 32M cache
seagate 750GB HDD 32M cache
hitachi 1TB HDD 32M cache
lg wh14ns40 bd burner
PostPosted: Mon Nov 26, 2012 11:23 pm    Post subject: Reply with quote
When recapping a board, recap ALL of the caps because bad brand = bad brand, no exceptions there, even if they are not doming/bulging yet, rest assured their ESR is skyhigh already and the voltage will be rippling like crazy...
PostPosted: Tue Nov 27, 2012 9:50 am    Post subject: Reply with quote
Have recapped several motherboards, all but one with success. And some video cards plus a PSU or two thrown in for 'flavor'.
Even if the capacitor shows no external signs, such as domed top or lifting off the board, internally it may be bad. Only the low ESR type capacitors should be used.. they have less internal Equivalent Series Resistance, and thus are favored for sensitive circuitry. The rating as to Micro Farads must be identical, as well as the voltage rating. Never use a lower voltage capacitor, but a higher voltage capacitor is sometimes acceptable. The preferred temperature rating for computer use is 105° C. A lower temperature rating could mean a premature failure. Certain brands are well known to have been "born bad", as noted in the thread about "Bad, Bad Capacitors" here on the Forum.
Sometimes, a capacitor may go for years with no problem, then suddenly go DOA. Heat is a major enemy of capacitors.
Some capacitors are intended to filter out the ripple or AC factor of DC power supplies.. others are intended to keep separate the DC voltages between circuits, yet pass the AC pulses.
An AC capacitor is merely two DC capacitors, connected in reverse serial fashion ( negative lead to negative lead, the positive leads brought out for connection).
The modern "dry" capacitor is now used all across the industries. No more "wet" capacitors, as years ago. Thankfully, they have gone out of favor. Not good to smell an acidic odor coming from a device as the capacitor's electrolyte boils off!!!
Sorry for the ramble. oops
Page 1 of 1
