Does this arrangement for my 3930k cpu sound alright?
Postby nownicked » Sat Nov 10, 2012 11:25 pm
Hello I have a H100 Currently an I wanted to upgrade because it makes a grinding noise. Are these components ok?
Btw I went for the triple rad because the double is not much cheaper.
PrimoChill Liquid Utopia Clear Additive 15ml
Noctua NT-H1 Thermal Compound
Scythe 120mm Gentle Typhoon 1850RPM Fan x 3
XSPC RX360 Radiator
Bitspower G1/4 Matte Black 1/2 Compression Fitting CC5
XSPC High Flex Hose, 1/2, Black
XSPC D5 Dual Bay Reservoir and Pump Combo
Koolance CPU-370SI CPU Waterblock Intel
This will be all going in the top of my coolermaster haf X case, i have measured up and the radiator will fit in the top, with the fans mounted on top. Any Suggestions about components?
nownicked
Return to The Water Cooler
