Karlsweldt Enlightened Master
Posted: Tue Nov 20, 2012 8:50 am Post subject: |
Welcome to Motherboards.org!
Surprised no one responded so far.
Almost all new motherboards are packed with the BIOS battery disabled or taken out.. to ensure any testing setups are back to default, and that you do get a good battery. But sometimes, a DOA battery comes with a board!
Check your manual as to where the jumper is, for clearing the CMOS.. and how the jumper should be for normal operation. If in doubt about the battery condition, get a new one. That battery also powers the real-time clock, and most motherboard models will not become active if that clock does not function!!
As to PSU connections, many are intended to be universal. But they connect in only one way, with physically configured pins. With the main power connector, almost all boards now default to the 24-pin ATX connector. But many PSU types may still default for the 20-pin + 4-pin type. For newer video cards, there may be a specific 4-pin, 6-pin or 8-pin connection. Depending on power consumption of the card, you need the specific connector. With many board designs, they require a separate +12 volt source for the CPU power needs.. a 4-pin socket near the CPU. If not connected, then perhaps no life-signs!
Regardless if the setup is "perfect", no life signs will be noted if the PSU does not present a 'power-good' signal after the load has stabilized. This comes from a gray wire on the main power connection. It should be at +5 volts, too low and the turn-on process will not be had. Try to get the system up and running in a basic configuration, with only what features are needed.. one hard drive, one optical drive, no extra case fans.
Use only a digital meter to measure voltages.. an analog type may load the source excessively and give false readings.
Memory is specific to a setup as to module type, speed and amount. And with many motherboard designs, either dual-channel or triple-channel memory intents are at hand. For either, you need matching modules of the identical memory type. Brand is not really a factor, but timing/density/amount is critical. For a preliminary setup, use only one module in the first-detected slot. That typically is "Bank 0, Slot 0". And until the BIOS pages are configured to the setup, you may have to default to a 1 GB or 2 GB module instead of a maximum amount.
As to posting photos, you would need a hosting service to link to.. or PM a Moderator about relaying that photo for posting.
Sorry for a long post, hope it was helpful. _________________ F@H.. to solve mankind's maladies.. in our lifetimes! |
