P5-S800VM/S memory and BIOS upgrade issue
Goto page Previous  1, 2, 3  Next
rascard2007
PostPosted: Tue Nov 13, 2012 9:02 am    Post subject: Reply with quote
evasive wrote:
Where did you find the information about the retail Asus board ROM name?.
Quite easy, I had before one of the retail asus boards, same model, so I still have the user manual and drivers CD and in the root directory of the drivers CD there is a P5S800VM.ROM file. in the manual when they explain how the EZ Flash works there is an example screen where U can read:
Reading file "P5S800VM.ROM". Completed
Start flashing...
so, I put 1 + 1 together wink
Iīm trying to get the user manual from the NEC site to see if they have somethig like this, but I canīt download from FTP servers
thanks again
SAM
-Wrapped Around Your Fingers-
-The Police-
rascard2007
PostPosted: Tue Nov 20, 2012 6:06 am    Post subject: Reply with quote
Any clue on the bios file name?
evasive:
Can U teach me how to extract the info from the .rom file and tell me please what tool I can use to do that,
many thanks in advance
SAM
-The Police-
PostPosted: Tue Nov 20, 2012 8:31 am    Post subject: Reply with quote
A BIOS file name is specific to the BIOS issue of the intended motherboard. But the file name of the 'new' BIOS program may not be the same. Revisions and changes dictate that result.. but the original program ID is still the same. In simpler words, the file name provided will be related to the current revision.. but after installation, the original BIOS string will be retained.. only the date may be different.
With most BIOS update programs, the required files are zipped into a smaller package.. for ease of transfer. An auto-extract feature (or manual operation) will unzip those files, for copying to a floppy disk or flash memory.
Newer motherboard designs may not have a floppy drive provision, so flash memory access would be the only way. But with older motherboard designs, a floppy disk is default. But the format for the floppy disk must be in FAT 12 format, otherwise the BIOS program cannot read the data!
However, with either case, you need a "boot path" for the flash process to begin!
It is prudent to save the old BIOS program to the update media.. just in case you need to "unflash" the system! But don't use the same file name as the new program. Use a tag name such as "old" or "bak" instead of "rom" or however the new file is named!!!
rascard2007
PostPosted: Tue Nov 20, 2012 11:27 am    Post subject: Reply with quote
Thanks Karl!
I understood that but my problem is that if the flashing process go wrong I have to go back to the original bios and as far as I know the oonly way of do that in this mobo is trough EZ flash or the CrashFree BIOS 2 utility, and both of them looks for a .ROM file with an specific name (P5S800VM.ROM in the ASUS retailed model)
what I need to know is the filename of the .ROM file that EZ flash and CrashFree applications look for in my case, because my mobo is a P5S800VM/S sold as OEM by NEC
my best regards
SAM
-The Police-
PostPosted: Wed Nov 21, 2012 10:35 am    Post subject: Reply with quote
Definition: Tagname: The last three characters of a file name, following a period or dot. This tagname allows associated files or programming to access it properly. While there may be several program files with the same first naming, and the same date/size, the tagname at the end denotes its association of use.
If, as in your case, the BIOS program is named "P5S800VM.ROM", then copy the original program as the same name, but use "old" or "bak" or other tagname to keep them separate. If in the future you need to revert to the original BIOS program, simply rename the 'new' file as "NEW" or some odd tagname that will not be recognized, then rename the old program as the "P5S800VM.ROM" entity. The flash utility should not have a problem.
Of course, wait at least two minutes after the process, to ensure a complete write, and if the system does not auto-reboot, then do so manually. The next step is to ensure that the CMOS is cleared to default. Then do the BIOS setup associations.
Some BIOS versions have a backup ROM file, as a "crash-free" design. The owner's manual would detail steps to utilize this feature.
rascard2007
PostPosted: Fri Nov 23, 2012 6:14 am    Post subject: Reply with quote
Karl:
You didnīt catch the idea
my board is P5S800VM /S a variant of the ASUS retail one OEMed by NEC, bios ARE incompatibles, and the name of bios file are different.
the file name of the new bios that I want to flash is NEC0216.ROM, that is not a problem because using the AFUDOS utility U can flash the bios with a .ROM file with any name.
BUT if the flashing process go wrong the only way to recover to the original bios is having it in the Floppy or CD with the ORIGINAL file name, the one with the OEM programmed the EZ flash and the Crash Free Utilities to search for in the CD.
So I have to rename my backed up bios with the EXACT file name that the utilities are expecting, and I have no clue on what the file name is.
thanks again,
SAM
-The Police-
PostPosted: Fri Nov 23, 2012 2:24 pm    Post subject: Reply with quote
The process does sound a bit confusing.. for those who have not done many BIOS updates. Yes, a BIOS program must match the motherboard model and type exactly, or there will be no end to problems.
The flash utility program will look for the specific "NEC0216.ROM" file to use for a BIOS update.
Following the suggestion I made, copying the original BIOS program as the same name, but use "NEC0216.OLD" instead of the provided file tagname will prevent an overwrite.
If the need comes to revert to the older BIOS program, simply change the tagname of the "NEC0216.ROM" file to "NEC0216.NEW" and then change the old program file to "NEC0216.ROM" and flash away with no likely problem. But if the process balks, noting the flash program file is older than what is present, it may be necessary to manually do the process. Read the batch file of the program to note arguments as a manual process.
Should be a help file associated with the utility.
You could also save a copy of the batch file as *.bak instead of *.bat, and then edit the original batch file to reflect the "NEC0216.OLD" file as the target. No need to backup/copy the program now installed, as it already exists.
PostPosted: Mon Nov 26, 2012 2:40 am    Post subject: Reply with quote
I'm seeing a P5S800VMROM string inside the P5S800-VM/S NEC0216.ROM bios file. So it looks to me they are not using a special /S name for the recovery ROM file.
rascard2007
PostPosted: Mon Nov 26, 2012 6:58 am    Post subject: Reply with quote
thanks evasive, I will make a test with the current bios first to see is EZ flash detects IT
SAM
-The Police-
PostPosted: Mon Nov 26, 2012 7:13 am    Post subject: Reply with quote
wise choice thumbup
Page 2 of 3
