Voyager22 Initiate
Joined: 27 Oct 2004 Posts: 35 Location: Allentown, PA USA
Posted: Wed Nov 07, 2012 8:49 am Post subject: Asus P8Z77-V LX Question on ATX Form Factor |
Thinking of replacing my old motherboard with an Asus P8Z77-V LX using an Intel i3-3225. The board is ATX form facotr, but less than the normal 9.6 inch width (actually 8.6 inches). It uses only six, not nine screws for attachment. Will this present any issue, especially since the MB extends out about an inch beyond the mid-screw placement. _________________ Asus P4P800SE MoBo
1.0 GB DDR3200 RAM
3.0 Ghz P4 Prescott CPU
Zalman Al-Cu Heatsink/Fan
Enermax 370W PSU
120 GB Hitachi Deskstar SATA HD
Soundmax Audio & Logitech 5.1 Speakers
Lite-On DVD & DVD-RW
Lian Li Black PC-61 Al Case
WinXP Pro SP2 |
Mr T Enlightened Master
Posted: Wed Nov 07, 2012 11:02 am Post subject: |
It will fit, but it means you cannot use the lower 2 5.25" bays for optical drives... _________________ I have been programming on computers since the ZX81.
Voyager22 Initiate
Posted: Wed Nov 07, 2012 11:25 am Post subject: |
No quite sure I understand how this relates to the optical drives. _________________ Asus P4P800SE MoBo
1.0 GB DDR3200 RAM
Enermax 370W PSU
WinXP Pro SP2 |
Posted: Wed Nov 07, 2012 9:25 pm Post subject: |
5.25" optical drives are long, so will hit the motherboard on the lower two 5.25" bays if you use them... _________________ I have been programming on computers since the ZX81.
evasive Mobo-fu Master
Joined: 06 May 2001 Posts: 36407 Location: Netherlands, Breda
Posted: Thu Nov 08, 2012 12:46 am Post subject: |
If this shorter board is used in a micro-ATX case it may be an issue.
If using an ATX case it will be fine. Just make sure you support the underside of the board with your finger when pushing in any connectors at that side (IDE, power etc). _________________ We hate rut, but we fear change.
Francesca Pilgrim
Posted: Wed Nov 14, 2012 9:53 pm Post subject: |
| maybe cannot use the lower 2 5.25" |
