cw4cam Brown Belt
Joined: 05 Mar 2004 Posts: 270 Location: Middlesboro KY
Posted: Mon Oct 08, 2012 6:10 pm Post subject: Windows 7 oem |
Why is oem windows packages so much cheaper. If i purchased an oem windows 7 O.S. would I have any difficulties using it? I know some of these oem systems are designed for specific brands of computers. Can they be installed on a new build? _________________ "A pessimist sees a problem with an opportunity. an optimist sees an opportunity with a problem."
Winston Churchill
Civilization is invaded by barbarians every generation. (author unknown) |
Toby B. Lead Mobo-fu Master
Posted: Mon Oct 08, 2012 10:31 pm Post subject: |
OEM versions of Windows 7 are identical to Full License Retail versions except for the following:
- OEM versions do not offer any free Microsoft direct support from Microsoft support personnel
- OEM licenses are tied to the very first computer you install and activate it on
- OEM versions allow all hardware upgrades except for an upgrade to a different model motherboard
- OEM versions cannot be used to directly upgrade from an older Windows operating system _________________ We Help You. You Can Help Us!
Link to us from your pages |
evasive Mobo-fu Master
Joined: 06 May 2001 Posts: 36380 Location: Netherlands, Breda
cw4cam Brown Belt
Posted: Thu Oct 11, 2012 7:30 am Post subject: |
Thanks folks. It helped.  _________________ "A pessimist sees a problem with an opportunity. an optimist sees an opportunity with a problem."
Winston Churchill
