Win 7 not updating at all
Goto page Previous  1, 2, 3
Post new topic   Reply to topic    The Mother Board Forum Index -> Operating Systems
visu
PostPosted: Thu Sep 20, 2012 4:40 pm    Post subject: Reply with quote
Solution 5: In-Place Upgrade
I see that the SFC scan detected corrupt system files but was unable to repair them. At this point, I would suggest that you perform an ‘In-Place Upgrade’ which will use the Windows 7 installation disc to repair corrupt system files. This process will not delete your files.
I have attached a document to this email which describes this process. If prompted for your product key during the In-Place Upgrade process, do not enter it at this point.
**attached file (minus screenshots)...
1. Log on to Windows 7 again..
2. Disable any 3rd party firewall, antivirus, or other security program to avoid it from possibly preventing the upgrade installation to Windows 7.
3. Place your Windows 7 installation DVD into the DVD drive and click on the Run setup.exe option in the AutoPlay window while logged into Windows 7.
NOTE: If the AutoPlay window does not open, then open the drive folder in Computer and run the setup.exe file.
4. Click on the Install Now button to start the installation.
5. Uncheck the I want to help make Windows installation better box (unless you want to), and click on the Go online to get the latest updates for installation option.
6. Windows 7 will now check online for and install any available installation updates.
7. Check the I accept the license terms box and click on Next.
8. For a In-place Upgrade Install -
A) Click on the Upgrade option.
10. The installation of Windows 7 will now begin.
NOTE: During the installation process, your screen may flash and computer will restart a few times.
11. After the final restart, you will see this screen for a moment.
12. Type in your Windows 7 product key number.
13. Uncheck the Automatically activate Windows when I'm online box unchecked, then click on the Next button.
14. Click on Use recommended settings.
15. Select your time zone and set your time and date settings, then click on the Next button.
16. Click on the option for your computer's location to select the correct network location type settings to be applied for that location.
17. Windows 7 will now prepare your desktop to startup.
visu
PostPosted: Thu Sep 20, 2012 4:48 pm    Post subject: Reply with quote
after that they took over by phone and remote access. so sorry i didnt document what they did. only one i did take note of was to download Windows6.1-KB947821-v22-x64 which returned an error during install
PostPosted: Thu Sep 20, 2012 11:39 pm    Post subject: Reply with quote
Sounds like windows 7 not ready for this chipset/APU or the chipset/APU itself has a bug?
MrG
PostPosted: Wed Oct 03, 2012 12:14 pm    Post subject: Reply with quote
Try the following 2 things:-
1. Add ALL of the following code into a .bat file and run it with Administrator priviledges:
Code:
net stop bits
net stop wuauserv
Del "%ALLUSERSPROFILE%\Application Data\Microsoft\Network\Downloader\qmgr*.dat"
rmdir %windir%\softwaredistribution /s /q
sc.exe sdset bits D:(A;;CCLCSWRPWPDTLOCRRC;;;SY)(A;;CCDCLCSWRPWPDTLOCRSDRCWDWO;;;BA)(A;;CCLCSWLOCRRC;;;AU)(A;;CCLCSWRPWPDTLOCRRC;;;PU)
sc.exe sdset wuauserv D:(A;;CCLCSWRPWPDTLOCRRC;;;SY)(A;;CCDCLCSWRPWPDTLOCRSDRCWDWO;;;BA)(A;;CCLCSWLOCRRC;;;AU)(A;;CCLCSWRPWPDTLOCRRC;;;PU)
cd /d %windir%\system32
regsvr32.exe /s atl.dll
regsvr32.exe /s urlmon.dll
regsvr32.exe /s mshtml.dll
regsvr32.exe /s shdocvw.dll
regsvr32.exe /s browseui.dll
regsvr32.exe /s jscript.dll
regsvr32.exe /s vbscript.dll
regsvr32.exe /s scrrun.dll
regsvr32.exe /s msxml.dll
regsvr32.exe /s msxml3.dll
regsvr32.exe /s msxml6.dll
regsvr32.exe /s actxprxy.dll
regsvr32.exe /s softpub.dll
regsvr32.exe /s wintrust.dll
regsvr32.exe /s dssenh.dll
regsvr32.exe /s rsaenh.dll
regsvr32.exe /s gpkcsp.dll
regsvr32.exe /s sccbase.dll
regsvr32.exe /s slbcsp.dll
regsvr32.exe /s cryptdlg.dll
regsvr32.exe /s oleaut32.dll
regsvr32.exe /s ole32.dll
regsvr32.exe /s shell32.dll
regsvr32.exe /s initpki.dll
regsvr32.exe /s wuapi.dll
regsvr32.exe /s wuaueng.dll
regsvr32.exe /s wuaueng1.dll
regsvr32.exe /s wucltui.dll
regsvr32.exe /s wups.dll
regsvr32.exe /s wups2.dll
regsvr32.exe /s wuweb.dll
regsvr32.exe /s qmgr.dll
regsvr32.exe /s qmgrprxy.dll
regsvr32.exe /s wucltux.dll
regsvr32.exe /s muweb.dll
regsvr32.exe /s wuwebv.dll
regsvr32 /s wudriver.dll
netsh winsock reset
net start bits
net start wuauserv
bitsadmin.exe /reset /allusers
shutdown /r
If that doesn't work, then:
2. Download WSUS Offline Updates Tool and see if that will do the updates for you.
visu
PostPosted: Fri Oct 05, 2012 6:12 pm    Post subject: Reply with quote
just an update. good news and bad news...
bad news - its going to take 4-6 weeks to sort out
good news - i think the culprit has been found
i spent like nearly 2 weeks with ms support. no solution.
i went back to the shop i bought them from, bringing the mobo with cpu and ram still attached. they test installed using their psu etc.... same problem.
using process of elimination, they replaced the cpu with one of theirs and everything went fine!!
they have a 1 for 1 exchange if i detect a problem before 7 days. unfortunately it was a couple of weeks in. so they've sent it back to the home of amd and i have to wait for a replacement which will take 4-6weeks.
thanks all for ur help. i will update again when i get the cpu back.
Post new topic   Reply to topic    The Mother Board Forum Index -> Operating Systems All times are GMT - 8 Hours
Page 3 of 3
