visu Initiate
Posted: Sat Sep 15, 2012 7:24 pm Post subject: Win 7 not updating at all |
I have done about 5 reinstalls now and havent fixed the problem. I just cant get the OS to update. The error codes I get are mostly 8e5e03fa and sometimes 8024000B. Ive googled till my fingers turned blue and tried just about every suggestion out there and nothing has worked. _________________ mobo: Gigabyte GA-A75M-D2H
processor: AMD A4-3400
ram: Kingston ddr3 pc1333 8gb(4gbx2)
ssd: Crucial M4 64 gb
hdd: WD Blue 1tb
psu: Silverstone SST-ST50F-ES
tv capture PCI: Kworld PVR-TV 7134SE
dvd rw: LG 24x SATA
case: Silverstone GD06
os: Win 7 Home Premium 64bit with SP1 |
Mr T Enlightened Master
Posted: Sat Sep 15, 2012 10:37 pm Post subject: |
Is it win7 without Service Pack 1... If so it is a common problem, manually download the service pack and install it, then updates will work... _________________ I have been programming on computers since the ZX81.
visu Initiate
Posted: Sun Sep 16, 2012 2:26 am Post subject: |
it has sp1 _________________ mobo: Gigabyte GA-A75M-D2H
hdd: WD Blue 1tb
dvd rw: LG 24x SATA
evasive Mobo-fu Master
Joined: 06 May 2001 Posts: 36410 Location: Netherlands, Breda
Posted: Sun Sep 16, 2012 3:49 am Post subject: |
You did this?
To resolve this problem, rename the Spupdsvc.exe file, and then try to install the updates again.
Is your system time/date set correctly? _________________ We hate rut, but we fear change.
Posted: Sun Sep 16, 2012 7:04 am Post subject: |
Have you tried restarting the windows update service in services.? _________________ I have been programming on computers since the ZX81.
Karlsweldt Enlightened Master
Posted: Sun Sep 16, 2012 7:53 am Post subject: |
Going directly to the MS update site should allow a check for any updates.. and then a listing of required ones. Yes, turn on automatic updates.. but set the choice as to installing for when you want to.. to avoid an unexpected shut down or restart! _________________ F@H.. to solve mankind's maladies.. in our lifetimes! |
visu Initiate
Posted: Mon Sep 17, 2012 6:32 pm Post subject: |
| evasive wrote: | You did this?
Is your system time/date set correctly? |
this is what i did...
If so to resolve this problem, rename the Spupdsvc.exe file, and then try to install the updates again. To do this, follow these steps:
Click Start, and then click Run.
Copy the following text, paste it into the Run box, and then click OK or press ENTER:
Cmd /c ren %WinDir%\System32\Spupdsvc.exe Spupdsvc.old
didnt work. date and time are correct _________________ mobo: Gigabyte GA-A75M-D2H
hdd: WD Blue 1tb
dvd rw: LG 24x SATA
visu Initiate
Posted: Mon Sep 17, 2012 8:46 pm Post subject: |
| Mr T wrote: | | Have you tried restarting the windows update service in services.? |
ran services.msc, stopped windows update, started it again. then tried windows update... no difference, same error codes _________________ mobo: Gigabyte GA-A75M-D2H
hdd: WD Blue 1tb
dvd rw: LG 24x SATA
visu Initiate
Posted: Mon Sep 17, 2012 8:50 pm Post subject: |
| Karlsweldt wrote: | | Going directly to the MS update site should allow a check for any updates.. and then a listing of required ones. Yes, turn on automatic updates.. but set the choice as to installing for when you want to.. to avoid an unexpected shut down or restart! |
which site do u go to? any website i try comes to this page...
hdd: WD Blue 1tb
dvd rw: LG 24x SATA
Posted: Tue Sep 18, 2012 5:34 am Post subject: |
This is the "official" site.. http://www.update.microsoft.com/microsoftupdate/v6/default.aspx?ln=en-us
If you have access errors, then use the Internet Explorer browser. MS frowns on "other" products, but will concede to other browser versions.
Their servers will determine what OS version you have, and what updates are required.. or optional, and present such.
But a caution about duplicating firewall or anti-virus programs.. they will compete for priority status, and can cause restrictions on site access!
Run only one version of each. _________________ F@H.. to solve mankind's maladies.. in our lifetimes! |
