visu Initiate
Posted: Wed Sep 12, 2012 5:33 am Post subject: Setting to change before installing Win7 |
I'm about to start my 1st (HTPC) build.
Can someone point me to, or spell out, a step by step guide to the BIOS settings that need to be changed before I install the OS?
This is the specs...
mobo: GA-A75M-D2H
processor: AMD A4-3400
ssd: Crucial M4 64 gb
ram: Kingston DDR3 PC1333 (4gbx2)
os: Win7 Home Premium 64bit |
evasive Mobo-fu Master
Joined: 06 May 2001 Posts: 36410 Location: Netherlands, Breda
Posted: Wed Sep 12, 2012 5:47 am Post subject: |
As far as I can tell there's no special settings needed for windows 7.
Do update your drivers after installing:
http://www.gigabyte.us/products/product-page.aspx?pid=3930#dl
Check the manual for additional information for the install, in general Gigabyte's manuals are quite decent. _________________ We hate rut, but we fear change.
visu Initiate
Posted: Wed Sep 12, 2012 6:08 am Post subject: |
| i came across this and didnt understand what to do. So can i presume its not necessary? |
Posted: Wed Sep 12, 2012 6:40 am Post subject: |
owww missed the SSD part completely.
I suspect most if not all of the settings are already right by default in the bios but it can never hurt to check. _________________ We hate rut, but we fear change.
Karlsweldt Enlightened Master
Should not be any special settings needed. But do set all control lines on the BIOS pages to how the system is configured. If there is a setting for modem use, disable that if not used. Same with audio or video features for on-board systems, if using a sound card or graphics card add-in. Set the controllers for storage drives as "auto" or "JBOD" unless setting up a RAID array. If using a USB type keyboard or mouse, enable the "legacy" feature for the USB ports. The default would be the PS2 ports. Otherwise, a keyboard or mouse would not be detected from USB ports, until the OS is active.
For the initial install of the OS, set the boot path to first check an optical drive, then the hard drive. After the install is solid, then set the hard drive as first choice for boot path. Only a DVD-type optical drive will work with the latest OS installs! _________________ F@H.. to solve mankind's maladies.. in our lifetimes! |
hunter1801 Black Belt 1st Degree
Joined: 17 Feb 2005 Posts: 1952 Location: Orange County, California
Posted: Wed Sep 12, 2012 6:23 pm Post subject: |
| Only thing I've ever worried about changing is boot priority. Changing it from a HD to a DVD drive so the Windows CD loads first. Normally, the stock settings are good to go. Other changes are just for further teaking. Never used a SSD though. |
Roach412 Black Belt 2nd Degree
Joined: 09 Aug 2004 Posts: 2460 Location: Milwaukee - Wisconsin
Posted: Wed Sep 12, 2012 7:39 pm Post subject: |
for my corsair drive i didn't have to do anything.
-Roach _________________ Lian Li Lancool First Knight Series PC-K59W
EVGA GTX 560ti FPB
Crucial M4 128gb SATAIII SSD
Corsair Professional Series HX850 PSU |
